Need help, check light everytime i boost over stock wastegate setting!!!
i'm on a stock ls with a complete greddy kit (ic, blue box, etc.). i wanted to go the safer route so i got rid of the 310cc injectors and now i'm running the dsm 450cc . stock wastegate spring is set on 5.5psi. everything runs fine, the car just runs a little rich but like i said i wanted to go safer with the 450cc. now here's the problem, i got an mbc on now but whenever i boost over 6psi, the car sputters and throws code #3 (MAP sensor) . i would like to know why it does this, and im just trying to get the car to run on 7psi. with what i have on, 3 mechanics have told me that i can run at 9psi with no problems. im not even trying to boost that much. i just want to leave it at 7psi. anyone, please share your knowledge.
p.s. im also on a resistor pack for the injectors. i replaced the first one thinking that it was bad, but after changing it i still get the same result .
Re: (evade this honda)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by evade this honda »</TD></TR><TR><TD CLASS="quote">could be a bad map sensor. I recommend putting in a gm 3 bar map sensor. </TD></TR></TABLE>
stock map is fine up till around 11psi. also he would have to re-program his ecu to recieve the 3bar. if i were you i would ditch the gay blue box and get tuned with crome,hondata,neptune...etc
Re: (SSBPGSR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SSBPGSR »</TD></TR><TR><TD CLASS="quote">stock map is fine up till around 11psi. also he would have to re-program his ecu to recieve the 3bar. if i were you i would ditch the gay blue box and get tuned with crome,hondata,neptune...etc</TD></TR></TABLE>
neptune,crome,uberdata
thanks guys, i'm on hondata on my other car so i'm familiar with it. i did this car by myself to learn installs of turbo kits and now i'm trying to work with the blue(gay) box. any more ideas for me? just trying to get it to run 7psi w/o the car limpin on me. thanks for ur help.
Modified by Hyper16-Johnny at 7:17 AM 12/28/2005
Re: (Hyper16-Johnny)
What I think you should do for your situation.. yank a virgin map sensor from local junk yard and go get a missing link perferabllly snapslink. how is your setting on a BLUE BOX are you in the negative sides. the lean side? One more thing.. my set up does that code 3 too. but funny thing is only if I hit 7 psi during day i get CEL and during night which is interesting I can boost to 10 ish 11 without one single CEL I dont know is it has to do with temperature or bar pressure.. I live in California in Temecula is you wonder. So now i got the missing link.. cant say that it works perfect...but maybe 2 times a day i may get the CEL compared to like..lets say every corner where i go...
Re: (vampire7608867)
thanks vamp, yea i get code 3 every now and then too...but i mostly get code 45. i don't think i'm leaning out since im on 450cc instead of the 310cc that the greddy kit comes with.
A cheap and easy fix would be check valves or a missing link but really dont recommend either.
stock MAP 10-11psi should be fine. You may just have a bad MAP
SOHC_MShue
09-20-2004 03:02 PM
