Quickest Spooling
Old Dec 30, 2005 | 09:19 PM
idewson's Avatar
Default Quickest Spooling
What is the goal for fast spooling...a lot of torque? large intercooler? Large downpipe? a combination of all?
Old Dec 31, 2005 | 03:49 AM
archmage's Avatar
Default Re: Quickest Spooling (idewson)
huh?
The goal of a quick spool is to achieve power at lower RPM...streetable powerband
Achieving this quick spool is dependent upon several factors, namely:
- Size of engine (capacity to spool the turbo)
- Turbo itself (sizing...look at compressor map; journal vs. ball bearing)
- manifold (equal length = good) and heat retention (thermal wrap)...but that's a smaller effect
what else...perhaps the tune, whatever...
Old Dec 31, 2005 | 04:59 AM
BlueShadow's Avatar
Default Re: Quickest Spooling (archmage)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by archmage &raquo;</TD></TR><TR><TD CLASS="quote">-manifold (equal length = good) and heat retention (thermal wrap)...but that's a smaller effect
Actually, I've read on here that log manifolds spool up faster but have poor topend, while EL's spool slower but have great topend. To me it sorta makes sense because if you look at the design of a log mani the exhaust gasses go right into the turbine via short runners at no regular interval. This means the exhaust gas gets to the turbine faster, but at upper RPMs the increased turbulence from the exhaust pulses all trying to get into the turbine hurt performance. While the EL manis have longer runners which means the exhaust pulses have to go slightly further to get to the turbine. But the lengths of the individual runners can be sized so the the pulses from each cylinder arrive at the turbine at regular intervals.
...or something like that, that's how I understand it anyways. Ask J Davis, he might be able to explain it better, hehehe.
civicgen3
Apr 22, 2008 09:47 PM
fasterthenU
Sep 13, 2007 10:59 PM
andysila
Feb 18, 2005 05:29 PM
BEEYOND
Dec 10, 2004 05:32 AM
Jared
Dec 6, 2004 07:06 AM
