checking compression with motor out and tranny off? HOW????
Old Dec 29, 2005 | 05:35 PM
the.hamburglar's Avatar
Default checking compression with motor out and tranny off? HOW????
how would i go abouts doing this? could a hook up an impact to the crank and pull all the plugs and turn if over with the impact?
Old Dec 29, 2005 | 05:45 PM
Finland's Avatar
no you can't. This will do you no good at all. Our Honda blocks and internals expand with heat, that's why you need to check compression after running the motor, getting it nice and hot.
Old Dec 29, 2005 | 05:51 PM
Default Re: (Boondock Saint)
i know you can hook up a battery to the starter but that has to be with the tranny on. i just want to make sure all the cylinders are close so i dont care about true readings. anyone else have comments about the impact?
Old Dec 29, 2005 | 08:39 PM
nos51's Avatar
Default Re: (the.hamburglar)
just use a leakdown gauge
Old Dec 29, 2005 | 08:49 PM
Default Re: (nos51)
how much is that? is it the same as a air pressure guage in the compression tester?
sleepinef
12
May 4, 2013 07:45 PM
JDM_EK_JOE
Oct 22, 2007 07:11 PM
DropSide
Apr 18, 2007 06:22 PM
spike
Jun 26, 2004 05:23 PM
Propulsion
Feb 14, 2003 11:11 AM
