can i run low compression pistons with a stock ecu/tune??
im starting the build of a b18c1 for turbo. if i wanted to swap the motor in with only low comp pistons (9:1) and no turbo would it run well stock or would i have to get it tuned?? the reason is that i want to get the motor in and running before i turbo.
thanks
adam
thanks
adam
Re: can i run low compression pistons with a stock ecu/tune?? (civicskater)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civicskater »</TD></TR><TR><TD CLASS="quote">im starting the build of a b18c1 for turbo. if i wanted to swap the motor in with only low comp pistons (9:1) and no turbo would it run well stock or would i have to get it tuned?? the reason is that i want to get the motor in and running before i turbo.
thanks
adam </TD></TR></TABLE>
It'll run fine, it'll just be slower than before.
thanks
7rrivera7
05-28-2007 02:38 PM
ahc'monracing
06-18-2003 02:05 PM
91, b18, b18c1, comp, compession, comppression, compression, ecu, low, lower, pistons, run, safe, stock, tune
