put me in the right direction
i have a 92 integra ls with a b18b i have megan headers, aem intake, skunk2 catback, cat delete pipe, i am going for 160 hp at the wheels with nitrous what else do i need, i am on a buget will not be using nitrous a alot NO FLAMING i just want info
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 89 pos »</TD></TR><TR><TD CLASS="quote">i have a 92 integra ls with a b18b i have megan headers, aem intake, skunk2 catback, cat delete pipe, i am going for 160 hp at the wheels with nitrous what else do i need, i am on a buget will not be using nitrous a alot NO FLAMING i just want info
That's pretty low power, so you shouldnt need anything else. Make sure your fuel and ignition systems are both in good. Get colder plugs, retard timing a little (dont know how much, I dont run n2o) and add a 50shot (wet).
</TD></TR></TABLE>That's pretty low power, so you shouldnt need anything else. Make sure your fuel and ignition systems are both in good. Get colder plugs, retard timing a little (dont know how much, I dont run n2o) and add a 50shot (wet).
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 89 pos »</TD></TR><TR><TD CLASS="quote">well i dont have a boat load of cash like every one else does</TD></TR></TABLE>
I think you took what I said the wrong way. I wasnt making fun of you when I said low power. What I meant is, that it doesnt take that much to make that power. So with what you have and a 50 shot, you should be ready to go.
my advice? be patient... instead of spending the money you have set aside now for nitrous or whatever, save it for a reliable well tuned setup.
Talk to Arthur at Trackmasters in Hunstville. Let him know how much money you can get together, and let him help you piece together a turbo setup. Let him tune it, and you'll have a fun reliable setup that will last a lot longer than a budget nitrous setup with no tuning.
just my .02
just my .02
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EVIL Hx Coupe »</TD></TR><TR><TD CLASS="quote">
I think you took what I said the wrong way. I wasnt making fun of you when I said low power. What I meant is, that it doesnt take that much to make that power. So with what you have and a 50 shot, you should be ready to go.</TD></TR></TABLE>
a 50 shot would ger you there with no supporting mods (assuming you have a strong motor) B18b`s are supposed to dyno between 118-121 whp. With those mods its most likely closer to 130whp, and with a 50 shot you might see close to 170whp. Nitrous is perfect for your budget and goals, just keep the fuel and timing conservative and you can have a lot of fun. Don`t think it won`t get expensive with bottle refills though
heat55561
Aug 11, 2006 11:23 AM
Ignitecivic
Mar 3, 2006 10:16 AM
