Electronic boost controller
Old Dec 29, 2005 | 07:25 AM
Meat_Wagon's Avatar
Default Electronic boost controller
I am looking for an electronic boost controller that will allow me to switch from one boost setting to another, on the fly, with just a push of a button. Any recomendations?
Price and simplicity are key factors.
Thanks
Old Dec 29, 2005 | 10:08 AM
red cx's Avatar
Default Re: Electronic boost controller (Meat_Wagon)
greddy has one that is pretty cheap. They also sell a button for it that mounts on your steering wheel. If you what to save a little money you can make up your own button.
Old Dec 29, 2005 | 10:14 AM
boostedcivicsir's Avatar
Mr. Badwrench
Default Re: Electronic boost controller (blue89crx)
the simplest that i know of is the turbo xs.
Old Dec 29, 2005 | 10:21 AM
PM-Performance's Avatar
Default Re: Electronic boost controller (boostedcivicsir)
Turbo XS isnt an EBC. Its an MBC> But its Super simple and works dead on every time. I wouldnt give mine up for the world
Old Dec 29, 2005 | 10:53 AM
vtec.dc2's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Meat_Wagon &raquo;</TD></TR><TR><TD CLASS="quote">I am looking for an electronic boost controller that will allow me to switch from one boost setting to another, on the fly, with just a push of a button. Any recomendations?
Thanks</TD></TR></TABLE>
apexi and blitz can offer preset levels of boost depending on speed/rpm.. you'd need 2 units to do that with blitz so it will cost some $$$$.. but blitz has overboost feature.. - automatic settings would be very simple and give you more time to concentrate on other stuff.
in general, i'm pretty sure more than a few boost controller will have some type of port for external switch to go back between 2 settings.. there aren't that many out there, check manufacturers website for external control option on these products
Old Dec 29, 2005 | 11:21 AM
Mr. Badwrench
Default Re: Electronic boost controller (PM-Performance)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PM-Performance &raquo;</TD></TR><TR><TD CLASS="quote">Turbo XS isnt an EBC. Its an MBC&gt; But its Super simple and works dead on every time. I wouldnt give mine up for the world</TD></TR></TABLE>
correct BUT the high low is technically, it is electronically controlled, and allows to switch from high to low.
Old Dec 29, 2005 | 12:14 PM
I guess you can consider it like that. But its really a Dual Solenoid MBC with a relay and switch.
You dont set it electronically, you just switch it electronically
Old Dec 29, 2005 | 12:30 PM
Meat_Wagon's Avatar
Is the turbo xs unit pretty solid when switching from low to high on the fly? Does it repond and open fast enough?
Old Dec 29, 2005 | 12:34 PM
Mr. Badwrench
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Meat_Wagon &raquo;</TD></TR><TR><TD CLASS="quote">Is the turbo xs unit pretty solid when switching from low to high on the fly? Does it repond and open fast enough?</TD></TR></TABLE>
it does on my friends 240, but it is internally gated. with a small turbo.
Old Dec 29, 2005 | 12:35 PM
Mr. Badwrench
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PM-Performance &raquo;</TD></TR><TR><TD CLASS="quote">I guess you can consider it like that. But its really a Dual Solenoid MBC with a relay and switch.
You dont set it electronically, you just switch it electronically </TD></TR></TABLE>
i see what you mean, i was going with because he was worried about price and simplicity, i think thats the simplest you can get.
Old Dec 29, 2005 | 01:04 PM
It switches as fast as any EBC will.
If you want simple and cheap and still effective this is the best bet.
If you want more bling and likely more headache on set up then go EBC.
I had an EBC before and ditched it for an MBC. Life is much easier now
Old Dec 29, 2005 | 01:32 PM
sp00led's Avatar
If you are set on getting a EBC then go with the Greddy Profect Type S....
I assume the Type S is for SIMPLE because it is as simple as it gets. Also, the optional remote high/low switch is pretty sweet. For only $100 extra you get the wireless steering wheel mounted button. I love mine, the switch is fast and seamless.
As basic as it gets with EBC.... i love mine
Old Dec 29, 2005 | 03:35 PM
swapit's Avatar
Default Re: Electronic boost controller (sp00led)
im using the turbosmart eboost2.its a pod mounted gage.i havent set up the boost stages but you can set it to switch with a button or by timer.going to setup when the tracks open.
Old Dec 29, 2005 | 04:00 PM
Meat_Wagon's Avatar
I like the steering wheel switch with the Greddy unit but the simplicity of the Turbo XS. Hmmm. . . .
Old Dec 29, 2005 | 04:29 PM
red cx's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Meat_Wagon &raquo;</TD></TR><TR><TD CLASS="quote">I like the steering wheel switch with the Greddy unit but the simplicity of the Turbo XS. Hmmm. . . . </TD></TR></TABLE>
the turbo xs dual stage is very simple to use. If you want to keep it real simple this would be a good idea
S2Kustom
Honda S2000
Sep 26, 2008 09:02 AM
VTEC_PRODUCTION
May 9, 2007 11:04 AM
boostincoupe
Jan 7, 2005 01:17 PM
Austinbionic316
Dec 8, 2003 06:18 AM
