should compressor nipple be plugged?
Old Dec 28, 2005 | 05:04 PM
cthan3o3's Avatar
Default should compressor nipple be plugged?
if im using a vacuum manifold should i plug the vacuum nipple on the turbo compressor? or should i just leave it open?
Old Dec 28, 2005 | 05:09 PM
turbotime's Avatar
yes plug it
Old Dec 28, 2005 | 06:30 PM
RudeLude's Avatar
Default Re: should compressor nipple be plugged? (cthan3o3)
leaving it open would be your best option, as that would bleed off the boost that your turbo will produce, this will result in the greatest amount of horsepower possible with any sized turbocharger! this will also produce alot of extra airflow under ur hood to keep everything under there cooler. o, and by the way, i'm kidding.
Old Dec 28, 2005 | 07:15 PM
dunkd's Avatar
uh if u dont plug it it will leak boost
Old Dec 28, 2005 | 07:17 PM
D@nnY's Avatar
Default Re: (dunkd)
that is a boost source and never sees vacuum.....it is supposed ot go to the bottom port of the wastegate
Bartman201
Nov 2, 2005 10:42 AM
sporkcrx
Jun 12, 2004 07:07 AM
underpressure02
Oct 6, 2003 08:14 AM
b18tdelsol
May 31, 2002 12:21 PM
Mucackus
Apr 18, 2002 07:55 AM
