s what do u think of the Blitz TWIN SBC?
Blitz TWIN SBC?
i need to know how to use it and hook it up
Modified by TurboEJ2 at 6:53 AM 1/4/2006
________
LadyNight18
________
LadyNight18
Re: s what do u think of the Blitz TWIN SBC? (TurboEJ2)
Re: s what do u think of the Blitz TWIN SBC? (ben@importparts.com)
I was thinking of getting that new color version. Looks hot and I hear the SBC's are pretty easy to use
Mr. Badwrench
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ben@importparts.com »</TD></TR><TR><TD CLASS="quote">The Blitz Dual SBC is the best boost controller you can buy for the money! We love it.</TD></TR></TABLE>
i have had it in my car for the last 3 years it is bad ***. if you want to go baller, there is the sbc id. same stepping motor. but different controls and face.
Re: s what do u think of the Blitz TWIN SBC? (boostedcivicsir)
nope lol i'ma go the cheaper route...well i'ma go ahead and order one then...thanks
________
Babe *******
________
Babe *******
and whats the idfferance in the hi and low settings? i didnt see a switch or anything to just change it while driving...just two ***** on the unit it self
________
Marijuana Bubbler
________
Marijuana Bubbler
Mr. Badwrench
no no, you set 4 preset boost levels. it goes in arbitrary numbers. the wastegate setting is 00, then (im pulling this out of my *** but) say 15 psi (if your wastegate base is 10 psi) will be like 22 or something like that. once you set all 4 of your settings, you just turn the **** to raise or lower boost.
as for the price, if it is a blitz dual sbc, it is worth it. they are like 500 shipped or something like that new. i paid like 450 with a hook up through my shop.
thanks alot...if i have any problems setting it or anything i'll let you know lol
________
Marijuana rehab advice
________
Hey anyone have any experince with the World interprise..or whatever Chris Rados company has. There boost controller is expensive but supposed to be the best for the money and the reason why cause its the most expensive..so no one is in its category..hahh..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TurboEJ2 »</TD></TR><TR><TD CLASS="quote">is it worth using?</TD></TR></TABLE>
its great. make sure to take advantage of boost cut feature.. turn the **** until its in red, then you can switch between 2 settings, one to set where its going to cut boost, the minus is to how agressive you want it to be cut.
Re: s what do u think of the Blitz TWIN SBC? (vtec.dc2)
whats the meaning of boost cut? sorry i've only worked with manual boost controllers
________
Aromed vaporizer review
________
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TurboEJ2 »</TD></TR><TR><TD CLASS="quote">whats the meaning of boost cut? sorry i've only worked with manual boost controllers</TD></TR></TABLE>
meaning you can set a max boost level to prevent overboosting.. lets say 0.70 kg/cm2 (10psi) and retract -20 or -30.. when you hit .70 kg/cm2, it will cut boost and won't allow you to overboost.. you switch between max level and how much to subtact by pressing right ****, the more you subtract, the more agressive the cut will be, if its not agressive enough, you might still overboost by a little, if its too agressive, it might become an inconvinience if you're trying to push near limit. i set it between 20-30
http://www.sportcompactcarweb....rol03/
That site, has a comparison of the latest boost controllers..well a couple of them..
