440 cc injectors?
Old Dec 29, 2005 | 07:59 AM
mugencivic94's Avatar
Default 440 cc injectors?
i have a greddy kit with a 15g on a d16z6 motors gettin built so im gonna push the 15g to 15psi will the injectors be able to put out enough for 15 psi or will i have to upgrade i also have a walbro 255lhp fuel pump thanks
Old Dec 29, 2005 | 08:08 AM
whoneedzvtec's Avatar
Default Re: 440 cc injectors? (mugencivic94)
yes, without a problem.
Old Dec 29, 2005 | 08:28 AM
emotionisdead's Avatar
Very Emergency!!
Default Re: 440 cc injectors? (whoneedzvtec)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by whoneedzvtec &raquo;</TD></TR><TR><TD CLASS="quote">yes, without a problem. </TD></TR></TABLE>
Old Dec 29, 2005 | 08:39 AM
HYREV2NR's Avatar
I'm running those on my R @ the moment. SC'd w/ 10 lbs of boost. they are running 86% duty cylce @ wot. So yes they'll be fine.
Old Dec 29, 2005 | 08:41 AM
b18a1ef9's Avatar
Default Re: (HYREV2NR)
will the emanage work with the 440's though just a question.
Old Dec 29, 2005 | 08:43 PM
Default Re: (b18a1ef9)
idk im using hondata s200b i sold the emanage
Old Dec 29, 2005 | 08:51 PM
JDMs1eeper's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mugencivic94 &raquo;</TD></TR><TR><TD CLASS="quote">i have a greddy kit with a 15g on a d16z6 motors gettin built so im gonna push the 15g to 15psi will the injectors be able to put out enough for 15 psi or will i have to upgrade i also have a walbro 255lhp fuel pump thanks
440's are plenty fine. with 95psi rail pressure I made 365.4whp and 274.8ftlbs at 90% duty cycle.... and at a base pressure of 43.5 they are good to support 254whp @ 80% duty cycle.
Old Dec 30, 2005 | 03:43 AM
turboman's Avatar
Default Re: 440 cc injectors? (JDMs1eeper)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMs1eeper &raquo;</TD></TR><TR><TD CLASS="quote">440's are plenty fine. with 95psi rail pressure I made 365.4whp and 274.8ftlbs at 90% duty cycle.... and at a base pressure of 43.5 they are good to support 254whp @ 80% duty cycle.</TD></TR></TABLE>
Thats good to know. I was concerned that my new purchase of 450s might have been a bad choice. I have a adjustable fuel pressure regulator perhaps I should install it.
If I have 300hp on my setup once tuned next week I will be one happy ******.
Old Dec 30, 2005 | 07:49 AM
JDMs1eeper's Avatar
Default Re: 440 cc injectors? (turboman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turboman &raquo;</TD></TR><TR><TD CLASS="quote">
If I have 300hp on my setup once tuned next week I will be one happy ******. </TD></TR></TABLE>
yeah 450's will be fine w/ added fuel rail pressure. Not only does this make the injector able to support more power, but it makes it more efficent. It'll vapoize a tone better meaning more fuel is being burnt instead of being pushed out the exhaust valves as un burnt fuel. Youll have less carbon build up and better gas milage. I current get 34-37mph with my LS vtec setup. Thats with getting on it every once in a while, city driving mixed with highway. So it "could" even emprove if I decided to go on a long highway trip w/ no gaggin it
mahatma
Jun 11, 2007 10:23 AM
SoyMilk
12
May 27, 2007 04:37 PM
lilo_goki
Mar 8, 2007 07:27 AM
eg6T
Dec 19, 2005 05:42 AM
S2KP
Oct 26, 2004 01:21 AM
