venting valve cover
Old Dec 27, 2005 | 03:49 AM
Stars's Avatar
I'm a Jackass
Default venting valve cover
I'm trying to think of new ways to do anything and everything, could any suggest a niffty ways of venting the valve cover.
like what kinda fittings are thoose, and lines, so anyways.. what about a long chatch tank that looks like a second radiator, mount that on the front rad support, so it looks like dual rads, and then have the lines at a 45 degree or 60 degree angle.. so it doesn't it my wastegate...
Old Dec 27, 2005 | 03:56 AM
Arturbo's Avatar
Better than steak
25 Year Member
Default Re: venting valve cover (Stars)
The hose ends are Earls and the hose is Earls Pro-lite.
Old Dec 27, 2005 | 04:03 AM
Stars's Avatar
I'm a Jackass
Default Re: venting valve cover (Arturbo)
what about venting from the top, like a 90 degree, and then mount it on the top twords the middle
Old Dec 27, 2005 | 04:28 AM
BlueShadow's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Stars &raquo;</TD></TR><TR><TD CLASS="quote">what about venting from the top, like a 90 degree, and then mount it on the top twords the middle</TD></TR></TABLE>
Are you talking about venting the top of the valve cover instead of the front/back of it? IMO it's pointless because you have to worry about it clearing your hood if you do it that way.
Old Dec 27, 2005 | 04:30 AM
Stars's Avatar
I'm a Jackass
Default Re: venting valve cover (BlueShadow)
im sure it would clear
Old Dec 27, 2005 | 05:01 AM
BoostedJeff's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Stars &raquo;</TD></TR><TR><TD CLASS="quote">im sure it would clear</TD></TR></TABLE>
you would be surprized, with a gsr motor in an EG, you only have about an inch between the valve cover and the hood... sometimes less
Old Dec 27, 2005 | 06:07 AM
evade this honda's Avatar
? hmmmmmm. what about the little filter near back of the valve cover. isnt that good enough? Now what specificaly does the catch can do?
Old Dec 27, 2005 | 07:15 AM
WHTZ's Avatar
Default Re: venting valve cover (BoostedJeff)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BoostedJeff &raquo;</TD></TR><TR><TD CLASS="quote">
you would be surprized, with a gsr motor in an EG, you only have about an inch between the valve cover and the hood... sometimes less</TD></TR></TABLE>
That's true.......Look at your valve cover from the bottom of the car with the hood closed. Not much space if any at all...
Old Dec 27, 2005 | 07:19 AM
shortyz21's Avatar
Default Re: venting valve cover (WHTZ)
to me these seem pointless.. is there any benefit?
or is it just the bling factor..
Old Dec 27, 2005 | 07:29 AM
dasher's Avatar
Default Re: venting valve cover (shortyz21)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by shortyz21 &raquo;</TD></TR><TR><TD CLASS="quote">to me these seem pointless.. is there any benefit?
or is it just the bling factor..</TD></TR></TABLE>
SS hose is more durable than regular hose.... personally I think it weighs too much for this application.
Old Dec 27, 2005 | 10:06 AM
Justin Olson's Avatar
Default Re: venting valve cover (dasher)
What is the deal with no filter on there? They just drilled holes in the top of the catch can for venting?
Justin
Old Dec 27, 2005 | 10:42 AM
dasher's Avatar
Default Re: venting valve cover (Justin Olson)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Justin Olson &raquo;</TD></TR><TR><TD CLASS="quote">What is the deal with no filter on there? They just drilled holes in the top of the catch can for venting?
Justin</TD></TR></TABLE>
Yep...
Old Dec 27, 2005 | 10:44 AM
splitime's Avatar
If it does clear, it'll be VERY close.
The other aspect of placing them on the front there, is using the stock valve cover baffling, to prevent loads of oil splashing into the lines.
Old Dec 27, 2005 | 11:09 AM
mike1114's Avatar
Default Re: venting valve cover (splitime)
I'm a big fan of this method. made by the same guy as the above picture.
Old Dec 27, 2005 | 12:15 PM
ladysman's Avatar
Default Re: venting valve cover (mike1114)
This is how my setup is vented. It is also drained back into the block on the passenger side fitting.
Old Dec 27, 2005 | 02:38 PM
turbotime's Avatar
i just use the hond fittings on the back of the block and T the valve cover into one of those 2 hoses.
Also I ran a hose from my catchcan vent to the bottom of the car cause the crap that comes outta there is gross.
There crap that stay in there is even grosser (unburnt fuel/oil/gunk)
catchcan is a MUST for FI imho
1Quikgsr
Sep 30, 2006 03:03 AM
d16dcoe45
14
Aug 6, 2006 03:12 PM
ozzyman
Feb 27, 2006 05:09 PM
xci_ed6
Dec 9, 2002 12:03 AM
-Whitey-
18
Sep 24, 2002 08:45 PM
