piston slap with cp pistons
Old Dec 26, 2005 | 07:38 PM
5thgearburnout's Avatar
Default piston slap with cp pistons
I have a 84mm ls vtec and it has some piston slap when cold. I have heard that cp pistons shouldnt make very much noise if any. Is this true or should I pull the motor out and take a look it?
Old Dec 26, 2005 | 07:50 PM
nonvtecD's Avatar
how much slap?
Old Dec 26, 2005 | 07:51 PM
program's Avatar
Default Re: piston slap with cp pistons (5thgearburnout)
cold piston to wall slap noise is common in low silicon hi expanding 2618 aluminum. However what is the piston to wall clearances?
Old Dec 26, 2005 | 07:54 PM
Default Re: piston slap with cp pistons (program)
I am not sure. I had golden eagle build the short block so it is set to what they set it to.
Old Dec 26, 2005 | 07:57 PM
nonvtecD's Avatar
My vitaras sound like a diesel and it runs fine.
Old Dec 26, 2005 | 08:21 PM
earl's Avatar
Default Re: (nonvtecD)
CP's do not slap unless the wrong piston to wall clearance is bored into the block. You would need to let us know the EXACT bore size of your block by measuring it, not what they told you it was.
Old Dec 26, 2005 | 08:48 PM
JDMs1eeper's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by program &raquo;</TD></TR><TR><TD CLASS="quote">cold piston to wall slap noise is common in low silicon hi expanding 2618 aluminum. However what is the piston to wall clearances?</TD></TR></TABLE>
I think that is backwards. high silicone has a high expanding rate. not low... but
Old Dec 27, 2005 | 04:51 AM
Default Re: (earl)
Is it something to worry about? Do you think that i should pulll the motor apart?
Old Dec 27, 2005 | 04:53 AM
Default Re: (earl)
I was also wondering if maybe they set them up lose since it is a turbo motor? Do you think that it could be a cracked skirt or something like that?
Old Dec 27, 2005 | 06:24 AM
igo4bmx's Avatar
Default Re: (earl)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by earl &raquo;</TD></TR><TR><TD CLASS="quote">CP's do not slap unless the wrong piston to wall clearance is bored into the block. You would need to let us know the EXACT bore size of your block by measuring it, not what they told you it was.</TD></TR></TABLE>
is that the case for every scenario?
i know i hear it alot when its below say 45 degrees out
Old Dec 27, 2005 | 10:04 AM
nonvtecD's Avatar
Does it go away when the motor warms up? being that it is forged, this should be the case...
Old Dec 27, 2005 | 10:09 AM
devoid's Avatar
Default Re: piston slap with cp pistons (JDMs1eeper)
nope..
low silicon pistons require bigger clearances, hence, knock more when cold
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMs1eeper &raquo;</TD></TR><TR><TD CLASS="quote">I think that is backwards. high silicone has a high expanding rate. not low... but </TD></TR></TABLE>
Old Dec 27, 2005 | 11:54 AM
program's Avatar
No, I got it right.
Bottom line; You may hear some noise when cold, and that's normal. But if the car is wormed up and you hear it, you may have a problem.
Old Dec 27, 2005 | 12:06 PM
Golden Eagle's Avatar
Bottom line; You may hear some noise when cold, and that's normal. But if the car is wormed up and you hear it, you may have a problem.[/QUOTE]
just what i was going to say
Old Dec 27, 2005 | 04:51 PM
JDMs1eeper's Avatar
No, I got it right.
Bottom line; You may hear some noise when cold, and that's normal. But if the car is wormed up and you hear it, you may have a problem.</TD></TR></TABLE>
I stand corrected. I got it backwards
Here is some info for you guys to read :
http://www.superstreetonline.c...23480/
Forging is a process that creates a solid chunk of uniformly grained metal. The details, features and sizes are then precision-machined from this piece to create a near jewel-like finished product. Forged pistons come from the aftermarket in various sizes, pin and ring locations, and dome configurations. Forged pistons signify a serious commitment to the engine’s performance potential; their ability to withstand heat and pressure at greater speeds inevitably means greater outputs than cast pistons. Most forged piston manufacturers offer two different alloys as the base material for the forged pistons. Forged pistons become stable at higher rpms, once their material expands, but can cause noise as they slap around in the cylinder walls at low speed when cold. The aluminum used for forged pistons differs in its proportion of silicone and copper, and thus offer different expansion rates. Additional silicone in a 4032 grade alloy yields a piston with lower heat expansion properties that maintains a tighter piston to wall clearance. Another grade of aluminum, 2618, contains less than one percent silicone with a higher content of copper. The composition of such pistons permit greater expandability and require greater piston-to-wall clearances, making it suited for the extreme heat and pressure caused by high-boost turbos, superchargers and loads of nitrous.
dplatt
Apr 29, 2010 01:46 AM
VtecbOi
25
Nov 1, 2005 06:43 PM
gsrjay
Aug 22, 2004 05:35 PM
turtle-eg
Jan 3, 2004 09:11 AM
crx1856
Nov 3, 2003 05:10 AM
