boosted 2.4 h22
Old Dec 31, 2005 | 11:31 AM
grappler's Avatar
Default boosted 2.4L h22
okay, my block has 89mm bored sleeves with wiseco pistons((8:8:1) which makes it 2.3 as everyone knows. But has anyone added the h23 crank and sometype of aftermarket high end h23 rod to get it to 2.4L and higher. Is it worth it especially for a turbo application?
thanks for any insight
Old Dec 31, 2005 | 11:50 AM
The Weather Man's Avatar
more torque is always a plus.
Old Dec 31, 2005 | 12:33 PM
prelittlelude's Avatar
Default Re: boosted 2.4L h22 (grappler)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by grappler &raquo;</TD></TR><TR><TD CLASS="quote">okay, my block has 89mm bored sleeves with wiseco pistons((8:8:1) which makes it 2.3 as everyone knows. But has anyone added the h23 crank and sometype of aftermarket high end h23 rod to get it to 2.4L and higher. Is it worth it especially for a turbo application?
thanks for any insight</TD></TR></TABLE>
the money and effort to increase your displacement is not worth it in a boosted app. just turn the boost up 2 to 3 psi and it will equate the same thing. the h23 crank will give you a lower redline and a crappier r/s ratio. stick with your current setup and get more power by assing more psi. the advantage to the h22 is that with the shorter stroke you can boost longer in each gear without having to shift.
Old Dec 31, 2005 | 01:16 PM
grappler's Avatar
Default Re: boosted 2.4L h22 (prelittlelude)
that is new info to me... I agree w/ u on the psi bumping...I did not know about the redline and r/s ratio issues.
Old Jan 1, 2006 | 03:28 PM
grappler's Avatar
bump
Old Jan 15, 2006 | 12:36 PM
1700anddroping's Avatar
https://honda-tech.com/zerothread?id=1282519
enought said.
h22_crx
Feb 13, 2007 12:17 PM
fastsohc
Aug 6, 2004 11:36 AM
crj_lll
Jul 8, 2004 03:08 PM
stinger
Oct 2, 2003 01:02 PM
