5 bolt flange with 3" dp?
Old Dec 29, 2005 | 10:24 PM
turtle-eg's Avatar
Default 5 bolt flange with 3" dp?
How do you guys run 3" downpipes with a 5 bolt flange since the opening is only 2.5"? Do you run a 2.5 and then flare it out to 3" or just weld a 3" pipe to the flange and dremel the flange out to 3"? Also, I think if 3" piping is used, it would obstruct the bolts.
Old Dec 29, 2005 | 10:33 PM
BlueShadow's Avatar
Default Re: 5 bolt flange with 3" dp? (turtle-eg)
You can get a 5 bolt 3" flange that allows you to weld a 3" pipe right onto it. If you are thinking about buying one check out http://www.atpturbo.com which is located in Fremont. They have a JS series flange which is 2.5" and tapers out to 3". Since you are located in NorCal it will take a day or two to get to where you are at. When I payed through paypal they didn't even wait for my paypal to clear which ususlaly takes 3-5 days. As soon as the paypal was set they would ship my items out a few hours later. If you order early enough it will even ship out on the same day.
Weld On 3" JS Series
http://www.atpturbo.com/Mercha...e=FLG
Old Dec 29, 2005 | 11:12 PM
B18C1CYA's Avatar
you can use a normal flange cus the turbo opening is only 2.5" or less on some i know the 5 bolt sc61 is bigger and there is a flange made just for that , but you will be fine to use a normal 5 bolt, and for bolts I always use allen head ones do to clearence issues,
Old Dec 30, 2005 | 05:45 AM
W O T's Avatar
Default Re: 5 bolt flange with 3" dp? (B18C1CYA)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18C1CYA &raquo;</TD></TR><TR><TD CLASS="quote">you can use a normal flange cus the turbo opening is only 2.5" or less on some i know the 5 bolt sc61 is bigger and there is a flange made just for that , but you will be fine to use a normal 5 bolt, and for bolts I always use allen head ones do to clearence issues, </TD></TR></TABLE>
happen to know what size the bolts are? I should pick up some of those today aswell
2001ZincSR
Nov 25, 2005 04:48 PM
zexifiedlude
Nov 12, 2005 02:03 PM
94TurboGSR
Sep 21, 2003 10:51 PM
W.Zero
Mar 12, 2003 09:58 PM
