running on 2 cylinders with cel 7 and 14
So I searched and searched and couldnt find what I needed.
I just put a d16y7 in my 95 cx for some boosting fun, I used the cx ecu harness and accessories, when It came time to get the motor started it started right up but runs like *** and throws phantom codes 7 & 14, so I replaced both the tps and iacv off of my old motor that I know to be good. Still throws the codes after clearing them. Now it seems to be running on only cylinders 1 and 4, I checked the timing, firing order and replaced plugs and wires. The dizzy is off of a good running car. Its getting fuel and spark (injectors off of good running car as well.) so what the expletive could be causing all this???
Re: running on 2 cylinders with cel 7 and 14 (extrmeboost)
Curious as to how you know its getting fuel and spark?
An engine will run with 3 things, fuel, spark and compression...if you dont have one of those 3 and at the proper time...it wont fire at all or poorly.
Re: running on 2 cylinders with cel 7 and 14 (xenocron)
i pulled all the plugs wires and stuck a screw driver in the end and watched it arc. I pulled the injectors and had a friend crank the motor and watched them spit fuel. That was retarted though cuz i damn near caught myself on fire. But what I'm wondering is are the injectors pulsing in the correct order? I know the firing order is correct and there is strong spark. I adjusted the valves and cylinders 2 and 3 valves were out of spec but it still didnt help. I am getting a compression tester today, so we'll see.
Try using an HEI spark tester...the screwdriver method is...uh...well.
Do you have a timing light to check your timing? Is the timing belt on correctly?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by extrmeboost »</TD></TR><TR><TD CLASS="quote">i pulled all the plugs wires and stuck a screw driver in the end and watched it arc. I pulled the injectors and had a friend crank the motor and watched them spit fuel. That was retarted though cuz i damn near caught myself on fire. But what I'm wondering is are the injectors pulsing in the correct order? I know the firing order is correct and there is strong spark. I adjusted the valves and cylinders 2 and 3 valves were out of spec but it still didnt help. I am getting a compression tester today, so we'll see.
The crank and cam timing is on but I have no timing cover to check the ignition timing??? but I got it all figured out and the car is running fairly smooth now. I did a compression check and saw good numbers and rechecked fuel and spark so I decided to play with the tps since I kept throwing that code. turns out when I replaced the bad tps I missed the little key that turns the sensor with the throttle, after I got that sorted out it ran alot better which allowed me to realize that there were some other small things wrong.
supracrx
10-29-2006 10:00 PM
extrmeboost
12-27-2005 12:13 PM
BlackDeuceCoupe
12-06-2002 06:13 PM
