is it safe to run a wastegate without spring?
Old Dec 26, 2005 | 10:26 AM
mrx's Avatar
mrx
Default is it safe to run a wastegate without spring?
Hi,
just a quick question, if i want to prevent my turbo from makeing boost (for tuning proposes) is it safe to run the car without a wastegate spring so that the wastegate is held open? or does the wastegate can be damaged from this?
Thanks
Old Dec 26, 2005 | 10:32 AM
veggiemaster's Avatar
Default Re: is it safe to run a wastegate without spring? (mrx)
Its just fine, but in higher RPMs you will build a bit of boost regardless. I did this for a good week without any problems.
Old Dec 26, 2005 | 10:43 AM
mrx's Avatar
mrx
Default Re: is it safe to run a wastegate without spring? (veggiemaster)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by veggiemaster &raquo;</TD></TR><TR><TD CLASS="quote">Its just fine, but in higher RPMs you will build a bit of boost regardless. I did this for a good week without any problems.</TD></TR></TABLE>
thats ok, just to get nearly atmospheric pressure to tune... thanks for the quick reply.
Best regards
D-meet07
Sep 23, 2019 03:06 AM
lsturboswap
Aug 13, 2007 02:05 PM
95srv
May 12, 2006 07:09 AM
sirb18a
Oct 19, 2003 01:49 PM
