headgasket and 82mm bore?
Re: headgasket and 82mm bore? (the.hamburglar)
You dont want a solid headgasket. Stay with an MLS style. We sell Cometic gaskets in various thickness's and I would recommend the HP gasket that offers better sealing for FI applications.
I would have to see if the .027" is available in the HP version. Im pretty sure its not since the extra thickness of the center layer around the bore brings it up a few thou. Best is to email me with your build and I could recommend a proper size. Be sure to tell me, if you know, how much material was removed from the block and head, what cams, valves, pistons, and what the piston/deck clearance is. Also desired compression ratio, or there abouts.
Dan@FSMoto.com is my email.
Dan
Dan
B18 CYA
04-15-2005 05:02 PM
