need help
Old Dec 27, 2005 | 08:35 PM
red beast's Avatar
Default need help
hello guys, i am new to the forum. i have a 96 civic coupe with a 92 ls motor, i am planning to turbocharge it. i was going to upgrade the piston and rods, but i was told i have to sleeve the block is that true. i would like to make around 350-370 hp is that possible
Old Dec 27, 2005 | 08:53 PM
EVIL Hx Coupe's Avatar
Default Re: need help (red beast)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by red beast &raquo;</TD></TR><TR><TD CLASS="quote">hello guys, i am new to the forum. i have a 96 civic coupe with a 92 ls motor, i am planning to turbocharge it. i was going to upgrade the piston and rods, but i was told i have to sleeve the block is that true. i would like to make around 350-370 hp is that possible</TD></TR></TABLE>
You dont have to sleeve the block to achieve the power level you want. Sleeving just adds to the reliability and also gives you rooms for quite a few rebuilds if you ever mess anything up.
If I was aiming for 370whp, I would go for:
Forged Pistons and Rods
Upgraded Valves/Springs/Retainers
Dont forget to get a good EMS and have it tuned by a professional. This is extremely important to get the desired power level and maintain good reliability.
Use the search function too. Search the forced induction section for B18B/A setups so you can look at what people are using to make the kind of power you want.
Goodluck.
Old Dec 30, 2005 | 03:13 PM
red beast's Avatar
Default Re: need help (EVIL Hx Coupe)
thanks for the info. what kind of pistons and rod and head upgrade you reccomend
Old Dec 30, 2005 | 03:52 PM
Pro-Am 1934's Avatar
Depends on how much you want to spend. You can get a set of Eagle 3/8" bolt rods for cheap, and go with either some Wiseco or Arias pistons for a good price as well. Or you can spend about $900 for some of the Manley rods and $500 or so for some CP pistons. All depends on the budget you have set.
Jason
90AcuraIntegra04
Nov 1, 2008 05:24 PM
SoloSol
Aug 11, 2004 07:32 PM
Honda-Hooligan
Feb 18, 2004 02:57 PM
ElectronVTEC
Mar 17, 2002 05:30 PM
DR. ON POINT
Nov 11, 2001 08:00 PM
