is it bad to have aft mrkt lightened flywheel on turbo car?
Re: is it bad to have aft mrkt lightened flywheel on turbo car? (turbomoe)
i dont believe that it would be because you are getting rid of reciprocating mass(hp killer) which helps any motor!
Re: is it bad to have aft mrkt lightened flywheel on turbo car? (fiend44)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fiend44 »</TD></TR><TR><TD CLASS="quote">i dont believe that it would be because you are getting rid of reciprocating mass(hp killer) which helps any motor!</TD></TR></TABLE>
it will help spool a little faster,but also fall out of the rpms faster.all this
means is "faster shifting"
IT is only bad if you want to put more power to your wheels, the miracle of reducing rotating mass
Also make sure your clutch is rated to rev as high as you want to rev your engine
cleanej2
09-04-2008 05:13 PM
ELITE 350Z
04-14-2004 12:57 AM
