Oil pressure sender question
Old Sep 4, 2006 | 02:57 PM
1158's Avatar
Default Oil pressure sender question
Looking for opinions of whether this will be ok or if it will break.
It's hard to tell, but the sender is mounted to a ge oil sandwich with a 90 and an extension. I tried using just the 90, but it hits the oil filter or the block.
Old Sep 4, 2006 | 03:18 PM
boostincoupe's Avatar
From: Destroying turbo ITR motors in Minneapolis, MN, U.S.A.
Default Re: Oil pressure sender question (1158)
That's so fucked.
Old Sep 4, 2006 | 03:24 PM
b18ccivics's Avatar
Default Re: Oil pressure sender question (boostincoupe)
it will break.
Old Sep 4, 2006 | 03:32 PM
SovXietday's Avatar
Default Re: Oil pressure sender question (b18ccivics)
Eek.
Make a brace for it and brace it with the firewall.
Old Sep 4, 2006 | 03:34 PM
1158's Avatar
Yeah, I kinda figured it wouldn't be wise to run with it like that. I think even I had been told it would work, I was going to do something else.
Old Sep 4, 2006 | 04:30 PM
platinum00's Avatar
That is the biggest sender i have ever seen. Get a smaller unit or that is not going to work
platinum.
Old Sep 4, 2006 | 04:36 PM
coneheadsracing's Avatar
Default Re: Oil pressure sender question (platinum00)
use a 45 off the sandwich, or relocate to the firewall.
Old Sep 4, 2006 | 04:41 PM
sc4dr's Avatar
Default Re: Oil pressure sender question (coneheadsracing)
Relocate it to the firewall. You can get stainless line in exact lengths from http://www.mcmaster.com or Flamenco-T just to name a few.
Old Sep 4, 2006 | 05:46 PM
1158's Avatar
I just ordered the stuff to mount it somewhere. I'm not in a hurry to get this done and the piece of mind is worth it.
Old Sep 4, 2006 | 05:49 PM
SONIC BOOM's Avatar
Default Re: (1158)
yikes. got alot going on right there
Old Sep 4, 2006 | 06:23 PM
Bailhatch's Avatar
Default Re: Oil pressure sender question (SovXietday)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SovXietday &raquo;</TD></TR><TR><TD CLASS="quote">Eek.
Make a brace for it and brace it with the firewall.</TD></TR></TABLE>
it would snap off the first time you shifted since the motor moves in relation to the fire wall. a brace to the block would be fine but kind of bulky.
Old Sep 4, 2006 | 06:32 PM
speedlabx2005's Avatar
Default Re: Oil pressure sender question (Bailhatch)
we have thick hi temp cooler lines at autozone in 5/16 or 3/8 diameter it sells for $ 1.50 a foot and route it to your fire wall i will try and take pics.
Old Sep 4, 2006 | 07:00 PM
Default Re: Oil pressure sender question (speedlabx2005)
Autozone parts
msd coil bracket $6.00
oil cooler lines hi temp thick 3/8 inner diameter $1.50 a foot 2 feet
male 3/8 barb fitting to 1/8 for the back of the block $1.50
1/8 tee $1.50
total $12.00
total cleaniness "priceless" just kidding
Modified by speedlabx2005 at 7:20 AM 9/6/2006
Old Sep 4, 2006 | 07:02 PM
Don't forget to notch the msd coil bracket to fit the autometer sending unit. dremmel then bolt it up hope this helps
Modified by speedlabx2005 at 8:41 PM 9/4/2006
Old Sep 4, 2006 | 07:41 PM
hope it works out for you
bigsnorlax
Jan 18, 2015 12:12 PM
TravisBiggie
Apr 24, 2012 08:01 PM
Pompiuses
Sep 3, 2010 09:29 AM
ImPuLsIvE
Jun 14, 2008 05:38 PM
planoguy36
Apr 9, 2006 08:09 PM
