Blowoff valve placement?
Old Sep 6, 2006 | 02:37 AM
Dollar_bill
Guest
Posts: n/a
Default Blowoff valve placement?
What are the advantages and disadvantages of placing the BOV on the hot side of the charge pipes as opposed to placing it on the cold side.Thanks all
Old Sep 6, 2006 | 03:51 AM
kameleon23's Avatar
Default Re: Blowoff valve placement? (Dollar_bill)
hmmm...blowing off hot air, instead of cooled air
Old Sep 6, 2006 | 05:22 AM
ykracing's Avatar
there seems to be some debate as to whether you want the BOV closer to the TB, or the turbo.
The concept is that the BOV releases the pressure on throttle close, to keep from surging back to the turbo. So, that being said, I've always felt that closer to the TB is a better layout, since it can react to the throttle close a millisecond sooner...
whether it actually makes any difference is probably immeasurable.
basically, there is probably little to no difference in the placement... whatever works for your setup will do the job.. IMO
Old Sep 6, 2006 | 06:29 AM
sorrule's Avatar
Default Re: Blowoff valve placement? (ykracing)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ykracing &raquo;</TD></TR><TR><TD CLASS="quote">there seems to be some debate as to whether you want the BOV closer to the TB, or the turbo.
basically, there is probably little to no difference in the placement... whatever works for your setup will do the job.. IMO</TD></TR></TABLE>
I put mine on the hot side and a buddy of mine put his on the cold side, about a foot from the TB, he still gets turbo flutter.
Old Sep 6, 2006 | 06:59 AM
QuarterMileMaster's Avatar
Default Re: Blowoff valve placement? (sorrule)
More info!!! I'm trying to decide on this as well!
Old Sep 6, 2006 | 07:20 AM
TurboCoop's Avatar
Default Re: Blowoff valve placement? (QuarterMileMaster)
Ive always heard 12-16" from the TB, I just figured you want it as far away from the turbo as possible for the least amount of compressor surge??? Thats where mine is and it seems to work fine. You have to run the vacumn line from the IM anyway and the shorter that is the better
Old Sep 7, 2006 | 09:46 AM
Default Re: Blowoff valve placement? (TurboCoop)
MORE INFO!!! I wanna see tests or something...
Old Sep 7, 2006 | 12:51 PM
HamiltonRex's Avatar
put it wherever you want.. Dosent matter.
I stuck mine up in the engine bay about 12" from the TB.. I keeps the vac line shorter too.
Old Sep 7, 2006 | 02:27 PM
turbo_ls_69's Avatar
alot of people i kno, put it right after the intercooler
Old Sep 7, 2006 | 02:56 PM
No-Gi's Avatar
Default Re: (turbo_ls_69)
I put mine right before the IC. On the hot side. Keeps the engine bay less cluttered.
TheOwnrOfTheEk9
Mar 9, 2006 12:11 PM
Beau Gotti
Sep 20, 2005 02:21 PM
sa90eg
Feb 23, 2005 11:49 PM
bearboy80
11
Apr 25, 2003 07:07 AM
Can't afford a Honda
Apr 9, 2003 07:03 AM
