please look at this turbo,
Old Sep 2, 2006 | 09:38 AM
integracivic94's Avatar
Default Turbo guru's please check in!
Found a turbo and i just wanted to know if it is any good? like will it spool fast like it says and can it support the power it claims? here is what the advert says-
BRAND NEW GARRETT T3/T4
This is a brand new Garrett hybrid turbo. This turbo is rated for 650 hp. This turbo is for someone that wants to have a really fast car. The compressor wheel that this turbo has is a GT40 the same compressor wheel as the new Garrett GT35R. This compressor wheel is from the new technology of Garrett. Also this turbo has the latest bolt down 360 degree thrust bearing design. This essential design ensures a long life, even under the most brutal racing conditions.
Turbine specs:
T3 6 bolt outlet turbine housing .83 A/R
76 trim T350 turbine wheel (stage 5)
Compressor Specs:
T04E housing 2.5" inlet 2.5" outlet
56 trim GT40 compressor wheel 2.41/3.22 (61mm inducer) and flow 65lb/min
Divided Turbo Flange
1 year FULL WARRANTY
Thanks for looking! regards russell
Modified by integracivic94 at 6:19 PM 9/3/2006
Old Sep 2, 2006 | 02:56 PM
Default Re: please look at this turbo, (integracivic94)
anyone got some opinions????
Old Sep 2, 2006 | 03:42 PM
ragethemachine86's Avatar
often times companies claim their turbos are more than they are. post up a pic so we can take a closer look at it.
Old Sep 2, 2006 | 10:31 PM
Default Re: please look at this turbo, (ragethemachine86)
will see if i can get a pic! i cant host it tho! anyone else with some thoughts or input?
Old Sep 2, 2006 | 10:45 PM
tonydatyga's Avatar
sounds like a phoenix turbo "blowzilla" t3/gt40 except for the stage 5 hot wheel and 6bolt discharge
Old Sep 2, 2006 | 10:48 PM
Default Re: please look at this turbo, (tonydatyga)
are these any good?
Old Sep 3, 2006 | 08:56 AM
anyone?
typer604
Mar 28, 2009 10:16 AM
B00STFREAKS
Nov 16, 2005 05:22 PM
SpiderSol
Oct 17, 2005 04:55 PM
