tuned on crome, can i use uberdata to datalog????
Old Sep 4, 2006 | 04:52 PM
blackeg's Avatar
Default tuned on crome, can i use uberdata to datalog????
can i use a different program than what the car was programmed with to datalog?? for example if i tuned a car on crome, could i use the datalogging cable and uberdata to log whats going on, or does it have to be the same program????
Old Sep 4, 2006 | 05:10 PM
nickromeo's Avatar
Default Re: tuned on crome, can i use uberdata to datalog???? (blackeg)
i couldnt get it to work.
then again i didint try that hard either.
i think it has something to do with the jumper u have to cut for crome for duplex and then in uber it doesnt need to be cut.
im not sure.
Old Sep 4, 2006 | 07:34 PM
xenocron's Avatar
Default Re: tuned on crome, can i use uberdata to datalog???? (nickromeo)
You cannot datalog an ECU with Uberdata that is running with code made in Crome.
You should be able to however, datalog with Freelog if the car is running on Crome.
Make sure J12 is cut in the ECU if you are doing this...
Old Sep 4, 2006 | 10:47 PM
mtber's Avatar
Default Re: tuned on crome, can i use uberdata to datalog???? (xenocron)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xenocron &raquo;</TD></TR><TR><TD CLASS="quote">You cannot datalog an ECU with Uberdata that is running with code made in Crome.
Make sure J12 is cut in the ECU if you are doing this...</TD></TR></TABLE>
+31337
Old Sep 5, 2006 | 02:20 AM
blackeg's Avatar
Default Re: tuned on crome, can i use uberdata to datalog???? (mtber)
thanks guys, that answered my questions 100%
nolicense526
Jun 27, 2007 07:02 PM
turbogsr181
Jul 21, 2006 10:22 PM
red-eg6
Sep 19, 2005 02:55 PM
TTWS6.
Aug 26, 2003 09:32 AM
ABTDer
Aug 2, 2003 03:20 PM
