running lean
Old Sep 3, 2006 | 09:46 AM
rdssk8rcs1's Avatar
Default running lean
could a crack in my intake manifold cause my car to run lean?
The other day when i was doing some pullson the highway i noticed my car was running lean, not terrible but about 12.5- 13 on my wideband, so i pulled over to check everything out, nothing really noticable was wrong under the hood but when i started looking at my honda logger i noticed my map sensor was reading about a pound or more less preasure than normal with my turboed car so i checked for boost leaks and found a pretty nasty one in the intake manifold
Old Sep 3, 2006 | 10:01 AM
Turbo-LS's Avatar
Default Re: running lean (rdssk8rcs1)
if your map sensor is reading less boost then it could make it run lean but if there is a boost leak then the engine isnt getting more boost then the map sensor is reading so if its that lean as you stated then you have a tunign issue. was it tuned on a hot day and you ran it in cooler weather or vise versa?
Old Sep 3, 2006 | 10:06 AM
rdssk8rcs1's Avatar
Default Re: running lean (Turbo-LS)
it was an average day, jeff evans tuned it, i trust his work, and i noticed is running noticably slower now im getting nervous
Old Sep 3, 2006 | 10:13 AM
Turbo-LS's Avatar
do a leak down test, i wouldnt be boosting it if the things in the 12's and 13's for a/f you need to be in the 11's. if you keep boosting it like that your goign to destyroy that motor if you havent already
Old Sep 3, 2006 | 10:19 AM
rdssk8rcs1's Avatar
no i havent since this happened, yeah thats my only worry i hope i havent messed anything up yet, i already ordered a new intake manifold....how do i do a leak down test?ive heard of them all the time and i have an idea of what it does just have no idea how to do one?
thanks for teh help
Old Sep 3, 2006 | 10:21 AM
Turbo-LS's Avatar
get a leak down tester and they come with instructions, or you can do a sinple compression tester, it wont tell you where the problem is but it will tell you if you have a problem
Old Sep 3, 2006 | 10:26 AM
rdssk8rcs1's Avatar
yeah i was going to do one first thing monday, so if nothing shows up wrong when i do a compression check im good?
but still what could be the problem with my car?
Old Sep 3, 2006 | 03:35 PM
rdssk8rcs1's Avatar
anyone else
Old Sep 3, 2006 | 03:37 PM
alpha's Avatar
Running leaner partial throttle? Checked battery voltage?
Old Sep 3, 2006 | 03:42 PM
rdssk8rcs1's Avatar
Default Re: running lean (0x64)
leaner at partial and open throttle, no i havent checked the voltage...
also my injecter duty is lower than it used to be
Old Sep 3, 2006 | 03:48 PM
alpha's Avatar
Check your battery voltage and post back
Old Sep 3, 2006 | 03:52 PM
rdssk8rcs1's Avatar
battery voltage can really effect duty cycle?
Old Sep 3, 2006 | 03:56 PM
alpha's Avatar
Examples. My own car. For one reason or another my battery voltage dropped to low 11's. My A:F went from 11.5:1 11.7:1 to 12.5:1 - 12.7:1. Recently tuning a car we lost an alternator belt. A:F went from 11.5:1 - 11.6:1 to 12.5:1. Had to add about 10% fuel to get it home
Old Sep 3, 2006 | 03:57 PM
rdssk8rcs1's Avatar
wow alright ill check that thanks
Old Sep 3, 2006 | 05:49 PM
OBRJosh's Avatar
Check your fuel pressure if you have a adjustable regulaterthe tighting nut couldv came loose
Old Sep 3, 2006 | 09:50 PM
dunkd's Avatar
What leak did you find in your intake manifold? Wouldn't that cause some nasty surging?
Old Sep 4, 2006 | 06:02 PM
rdssk8rcs1's Avatar
Default Re: (dunkd)
its a crack at the bottom of the runner near the injector
blkdoutteg
Aug 30, 2012 05:55 PM
rdssk8rcs1
Oct 10, 2006 06:43 AM
rdssk8rcs1
Sep 3, 2006 03:24 PM
Brightazzsi
Oct 17, 2003 01:37 PM
turboegg
May 2, 2003 04:32 AM
