post up your ls/vtec-t setups
Old Sep 3, 2006 | 10:15 AM
Fezzie's Avatar
Default post up your ls/vtec-t setups
ok well im building a ls/vtec turbo and i want to know some good setups i havent bought my turbo kit yet im still building the motor
what I have:
b18a1 block:
ctr pistons (about to buy diff)
type r oil pump
ls/vtec kit
fidanza 8lbs flywheel
gsr head:
skunk2 stage2 cams
skunk2 intake manifold
arp head studs
b16 tranny
things i havent bought yet:
valvetrain
clutch
header
starter, altenator
axles
ecu
misc. bolts, brackets
gaskets
Old Sep 3, 2006 | 12:59 PM
Fezzie's Avatar
Default Re: post up your ls/vtec-t setups (Fezzie)
anyone
Old Sep 3, 2006 | 01:04 PM
komat's Avatar
theres a thread with only lsvtec do a search for it
my is in my sig
Old Sep 3, 2006 | 04:36 PM
methos713's Avatar
I'm in the process of building mine too. I'm just waiting on saving more funds to get the turbo kit and head components...plus misc. stuff. Might not get done until next summer. This is what I have now...
Benson sleeve b18b block
low com. JE pistons
crower rods
stock gsr head
GE ls/v kit
aebs headstuds
apex'i vtec controller
LS tranny
motor mounts
axles/halfshaft
.48 a/r turbo (will be selling this, since its too small and was orinally for my sohc...going to go with a .57 trim)
Old Sep 4, 2006 | 12:34 AM
Fezzie's Avatar
Default Re: post up your ls/vtec-t setups (methos713)
Old Sep 4, 2006 | 05:03 AM
DaveF's Avatar
https://honda-tech.com/zerothread?id=1549069
Old Sep 4, 2006 | 07:18 AM
Fezzie's Avatar
Default Re: post up your ls/vtec-t setups (dturbocivic)
Old Sep 5, 2006 | 10:32 AM
Fezzie's Avatar
up
Old Sep 5, 2006 | 11:12 AM
Rikter's Avatar
Look and you will find within the first two pages of the thread lists a section devoted to LS/Vtec turbo setups. I think theya re at over 120pages! This thread fo yours will not yeild the results you're looking for. Go read that thread for a few days and you will find what you're looking for.
-Rik
Old Sep 5, 2006 | 01:16 PM
Mugencrxsir1's Avatar
Default Re: (Rikter)
You guys are thinking of an LS only thread, it's not ls/vtec like the topic said. If you read through the thread, it's all ls builds and not ls/vtec. Regardless here's mine:
Head:
b16 Ported
gsr cams, 5 bolt edelbrock cam gears
buddyclub valve springs
GE fuel rail
Rev hard IM, hondata gasket
Precision 880cc injectors
custom ramhorn Ex. Mani
3" Full race DP
Custom kteller 3" SS exhaust
Walbro 255 lph
Block:
CP 9.1 pistons
eagle rods w/ arp bolts
stealthmodeperformance turbo oil kit
GE ls/vtec kit
kms block guard
gsr oil pump
b16 water pump
ARP head studs
stock crank
ACL bearings
moroso stock oil pan
Other:
Turbonetics t3/t04e 60trim, .63
hondata s200 boost etc...
jkobd wiring harness
Y1 tranny, LSD ACT XTSS w/ streetlite flywheel
place racing front crossmember
Old Sep 5, 2006 | 05:09 PM
Fezzie's Avatar
Default Re: (Mugencrxsir1)
nice
bigmike305
Sep 29, 2009 04:15 PM
silverdc2integra
Sep 28, 2009 11:17 AM
blackeg
Nov 25, 2005 06:00 AM
hatchmonkey92
May 5, 2005 09:25 AM
quickLSt
Jun 29, 2002 11:45 AM
