do i need a oil catch can?
Old Sep 5, 2006 | 06:15 AM
92 CIVIC HATCH VX's Avatar
Default do i need a oil catch can?
ok i'm about to install my setup and it should push 450-550 hp.
instead of a catch can. can i run a line from my valve cover to the bung on the turbo drain?
let me know, i think it should drain just fine.
Old Sep 5, 2006 | 07:22 AM
boostedcivicsir's Avatar
Mr. Badwrench
Default Re: do i need a oil catch can? (92 CIVIC HATCH VX)
to answer, yes, then no.
yes you need a can, no you shouldnt run it to a bung on the oil drain.
you need a place for the pressure to escape, and the catch can is the best way to do it. i am running the endyn kit for now, but on the new gsr, there will be a ported valve cover goin on.
Old Sep 5, 2006 | 07:30 AM
Default Re: do i need a oil catch can? (boostedcivicsir)
could i put a filter on the regular vent and weld a new one on the front..... damn that still might make a mess?
Old Sep 5, 2006 | 07:31 AM
turbotime's Avatar
yes you need a catchcan
no you cant drain back to the return its just pressurizing the same system.
see diy in sig.
ninjaedit- yeah if you just put filter on you valve cover your gonna have one messy enginebay
Old Sep 5, 2006 | 07:35 AM
Default Re: (turbotime)
well i'm running a built h22 do you know if those ports are the same as the b18c?
Old Sep 5, 2006 | 07:36 AM
turbotime's Avatar
Default Re: (92 CIVIC HATCH VX)
i believe so becuase the block fittings from honda are actually for the h22/23 i believe
Old Sep 5, 2006 | 11:24 AM
swappedcx's Avatar
its really cheap to make a DIY catch can. My block fittings and washers were $21 from my dealer, spent $5 on some tubing, like $2 on hose clamps, and $8 on a mini vent. I had some scrap metal lying around so i just welded that into a box and bought some $.90 fittings from home depot. Might not look as pretty as a $140 Endyn setup, but for under $50 and it works the same way how can you complain?
aleks77
Nov 10, 2022 01:51 PM
huge230
Mar 4, 2007 03:17 PM
THEDirtyDseriesWOOT
Aug 31, 2006 01:23 PM
nerdsports
May 10, 2003 11:47 AM
Ltech
Apr 2, 2003 01:10 PM
