when is the 38mm wastegate a restriction
Old Sep 6, 2006 | 07:43 AM
Quickgti1.8t's Avatar
Default when is the 38mm wastegate a restriction
when does the tial 38mm become a restriction. i'll be running a GT35R .63, tubular mani etc etc. i have a choice of either 38mm flange or 44mm flange.. Minimun boost i'll be running will be 20-22psi on pump and up to 35psi on race. The mani design will be like dual wastegates but it will go into 1 wastegate... What do you guys think
Old Sep 6, 2006 | 09:07 AM
Mugencrxsir1's Avatar
Default Re: when is the 38mm wastegate a restriction (Quickgti1.8t)
In your case, I would definately run a 44mm wastegate if you plan on running 20+psi on the street and 35psi at the track. A 38mm wastagate can handle the 20 psi, but definately stressing on the 35psi.
Old Sep 6, 2006 | 09:29 AM
Default Re: when is the 38mm wastegate a restriction (Mugencrxsir1)
I had this same set-up last time but i used a 38mm wastegate. I ran it up to 26psi but i was getting surging like the boost was going back and forth 1-2psi real fast. So i dont know, might do 44mm i guess
SAMCRO08
Oct 17, 2013 11:43 AM
Nermin
Aug 3, 2011 09:22 PM
gsr x civic
Apr 7, 2007 09:57 AM
boostedB16a1
Dec 4, 2006 11:04 AM
BlackGSR
Apr 16, 2002 07:44 AM
