what size injectors?
Old Sep 5, 2006 | 07:53 PM
rsdriver17's Avatar
Default what size injectors?
i will be using an IHI turbo on my b18a1 @ 10lb (verysmall) what size injectors should i run. i was thinking eather 310 or 390's. at hand i have DSM blue top 450's. a little big i think? i duno
Old Sep 5, 2006 | 07:57 PM
siblues's Avatar
Default Re: what size injectors? (rsdriver17)
What management are you going to use ?If its a standalone then you can pretty much use anything and tune for it
Old Sep 5, 2006 | 08:01 PM
rsdriver17's Avatar
Default Re: what size injectors? (siblues)
im just going to chip the ecu, im new at turbo **** but i know stuff to get it started
Old Sep 5, 2006 | 08:05 PM
siblues's Avatar
I think you will be ok with the 450;s if whoever is making the chip knows what he is doing
Old Sep 6, 2006 | 09:48 AM
rsdriver17's Avatar
anymore!
Old Sep 6, 2006 | 10:28 AM
Mugencrxsir1's Avatar
450's are fine for what you are doing, and leaves you a little extra boost control room for later.(I would'nt go above 12psi with 450's)
Old Sep 6, 2006 | 10:52 AM
urbansi's Avatar
Default Re: what size injectors? (Mugencrxsir1)
As far as hp levels i would say that 450's are good till around 250-280whp depending on other upgrades ie: fuel pump and FPR
Old Sep 6, 2006 | 11:36 AM
Jay_Sensing's Avatar
You can run 1000cc injectors in a stock non turbo car with a chipped ECU and a good tune. The 450's will be fine.
Next, don't worry about what psi you run the injectors to, it's HP that limits them and HP isn't a constant among different turbos with different boost levels. I have seen several DSM injectored cars make 330 hp at the wheels with a Walbro 255 and stock FPR and be around 80-85% DC so you are fine up until that point.
Old Sep 6, 2006 | 11:46 AM
WickedHonda00's Avatar
"I have seen several DSM injectored cars make 330 hp at the wheels with a Walbro 255 and stock FPR and be around 80-85% DC so you are fine up until that point."
This guy ^^^ knows what he is saying. D series fuel pumps can handle a little over 300whp, B series pumps maybe 375whp. Just a bit more info related to the subject. 400cc+ are definately good for 300whp no problem with the right tuning.
Adam R.
Feb 19, 2013 07:38 PM
DC2fab
Apr 9, 2010 09:31 PM
stock ek
May 15, 2007 02:31 PM
Project_DX
16
Jul 30, 2006 08:09 AM
hotimportcrx
May 17, 2005 04:10 AM
