code 23 hondata s300 problems
Old Sep 3, 2006 | 12:04 PM
JICEK9's Avatar
Default code 23 hondata s300 problems
i just finished installing rc440's and a s300 on my jrsc d16y8. as soon as i start the car it throws a code 23, knock sensor. if a clear it, it comes right back on even when ideling. i am using a base map that i downloaded from hondata for a jrsc d16 w/ 12ohm 440's. i thought the car would at least idle w/o issues. i'm bringing it to the dyno asap but now i am wondering if it is safe to drive??? any ideas???
Old Sep 3, 2006 | 12:07 PM
ladysman's Avatar
Default Re: code 23 hondata s300 problems (JICEK9)
Disable the Knock Sensor in the software.
Old Sep 3, 2006 | 12:15 PM
JICEK9's Avatar
Default Re: code 23 hondata s300 problems (ladysman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ladysman &raquo;</TD></TR><TR><TD CLASS="quote">Disable the Knock Sensor in the software.</TD></TR></TABLE>
it was disabled on the base map.. do i really want to disable it? i thought it was a safety feature, thats why i enabled it...
Old Sep 3, 2006 | 12:25 PM
ladysman's Avatar
I never use the honda knock sensor with a turbo but that is me. It is too sensitive.
I would disable it.
Old Sep 3, 2006 | 12:30 PM
Shmaa's Avatar
If its throwing a code its not working in the first place so disable. Do you even have a knock sensor???
Old Sep 3, 2006 | 12:32 PM
JICEK9's Avatar
i never had any cel's until now. i have been running the jrsc with the fmu crap for 3 years w/o one CEL. just a little concerned... what could cause this? my ignition timing? any over thoughts???
Old Sep 3, 2006 | 12:34 PM
PrecisionH23a's Avatar
I agree. What ecu are you using?
Old Sep 3, 2006 | 12:35 PM
JICEK9's Avatar
Default Re: code 23 hondata s300 problems (Shmaa)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Shmaa &raquo;</TD></TR><TR><TD CLASS="quote">If its throwing a code its not working in the first place so disable. Do you even have a knock sensor???</TD></TR></TABLE>
i think so. it's a 2000 civic ex with the stock d16y8. it didn't throw this code until i installed the hondata.
Old Sep 3, 2006 | 12:36 PM
JICEK9's Avatar
Default Re: code 23 hondata s300 problems (PrecisionH23a)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PrecisionH23a &raquo;</TD></TR><TR><TD CLASS="quote">
I agree. What ecu are you using?</TD></TR></TABLE>
p28
Old Sep 3, 2006 | 01:02 PM
nfn15037's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JICEK9 &raquo;</TD></TR><TR><TD CLASS="quote">p28</TD></TR></TABLE>
P28s don't have a knock sensor bord. Disable it or add knock capability to the board, harness, and motor.
Old Sep 3, 2006 | 01:12 PM
JICEK9's Avatar
Default Re: code 23 hondata s300 problems (nfn15037)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nfn15037 &raquo;</TD></TR><TR><TD CLASS="quote">
P28s don't have a knock sensor bord. Disable it or add knock capability to the board, harness, and motor.</TD></TR></TABLE>
thats exactly what i was thinking. I'm so thankful for H-T and all the smart people on here so glad to be a member.
btw-I did search, I'm surprised this has not been covered before.
Old Sep 3, 2006 | 04:11 PM
ladysman's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JICEK9 &raquo;</TD></TR><TR><TD CLASS="quote">thats exactly what i was thinking. I'm so thankful for H-T and all the smart people on here so glad to be a member.
btw-I did search, I'm surprised this has not been covered before.</TD></TR></TABLE>
I told you in post 2 what to do.
I guess I should have told you why since Hondata = OBD1 conversion. My bad.
Old Sep 3, 2006 | 04:33 PM
bingo
Old Sep 3, 2006 | 06:42 PM
Shmaa's Avatar
I have an ECU socketed for S300 with a knock board if you want
IF you didn't know, once you disable it, it will not throw any codes.
brcivic411
17
Aug 26, 2011 01:15 PM
SpoonFedEj8
Dec 23, 2008 03:11 PM
birds_sol_94
Aug 19, 2004 04:23 PM
99spanishGT
Mar 26, 2004 12:40 PM
