which turbo should i look for 400-450HP (B16A2 9:1)
hello everybody.
i'm looking for a turbo for my b16a2 that will make 400-450 hp with 9:1 cr
i need boost at about 3000-3500 rpm and i need it to hit hard from that point to the rev limiter...
which one would you recommend?
any holset turbo's that will work for me?
thanks...
thanks...
Re: which turbo should i look for 400-450HP (RACEPAK)
Is the motor stock bore?
Since you're looking for something with really fast spool, the GT series is your best bet. The 28RS spools within your 3000-3500 rpm goal, but will not make the hp you're looking for. You could go with the 3071r .63 a/r to influence quicker spool, but you're probably looking at 4000-4500 rpm.
If its a bigger bore size then you might like the precision sc34 or the sc32. The 34 is rated up to 540 ish flywheel and the 32 is 490 ish flywheel. Ive used a bunch on stock b series motors and theyve worked great so far.
Canadian_EF
11-12-2012 07:37 PM
