boost creeping
Old Sep 4, 2006 | 06:21 PM
slodc2's Avatar
Default boost creeping
i have a stock jdm b16a in a civic hatch w/ a nuekin ramhorn manifold, tial 38mm wastegate w/ a 8psi spring, and precision sc61 turbo..i have the vac line ran from the wastegate to the turbo and i dont see any vac leaks in the line...once i hit vtec it goes to 10psi, i only want to run 8psi...any suggestions?...if i buy a 6psi spring do yall think it will hold at 8ish psi?
thanks alot
Old Sep 4, 2006 | 08:29 PM
turbo_ls_69's Avatar
Default Re: boost creeping (slodc2)
do u have a boost controller?
Old Sep 4, 2006 | 08:46 PM
turbotime's Avatar
hm maybe a 44mm gate?
where is the boost gauge ran off?
Try running the gate off the brake booster....
Old Sep 5, 2006 | 12:44 PM
slodc2's Avatar
no i dont have a boost controller...im running straight off the wastegate spring...i was thinking a 44mm wastegate would solve it also but my manifold is flanged for a 38mm and i really wanna keep my manifold...the boost gauge is ran off a golden eagle vacuum manifold which is tapped into my break booster line...and suggestions?...do yall think if i put a 6psi spring in, that it will hold at 8ish psi?...thanks alot
Old Sep 5, 2006 | 12:48 PM
turbotime's Avatar
tap the wg off the brake booster..... not the compressor housing and use a good sized line.
Old Sep 5, 2006 | 12:54 PM
Mugencrxsir1's Avatar
Default Re: (slodc2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slodc2 &raquo;</TD></TR><TR><TD CLASS="quote">no i dont have a boost controller...im running straight off the wastegate spring...i was thinking a 44mm wastegate would solve it also but my manifold is flanged for a 38mm and i really wanna keep my manifold...the boost gauge is ran off a golden eagle vacuum manifold which is tapped into my break booster line...and suggestions?...do yall think if i put a 6psi spring in, that it will hold at 8ish psi?...thanks alot</TD></TR></TABLE>
You can always have a 44mm wastegate flange welded on your manifold.
Old Sep 5, 2006 | 01:12 PM
Turbo-LS's Avatar
this is very common with thos emanifolds. there wg port isnt cleaned up and doesnt alow good flow also you should move up to a larger wg. someone else had this issue in another thred they moved to the 44mm wg and cleaned up the burs on the opening and it works just fine now
Boosted00
Jan 19, 2018 01:51 PM
pv2dickman
May 27, 2005 05:59 PM
B16CRXT
Apr 24, 2005 07:50 PM
turbodohcsi
Jun 3, 2004 11:02 PM
Wo-Nelly
Feb 23, 2004 01:28 PM
