surging/sweeking problems with typeS style bov
MAJOR SURGE run 1/2
http://youtube.com/watch?v=EM7k-P21bvU
freeway 3rd gear/// i belive its surge?
http://youtube.com/watch?v=0EJJovYEUZ0
loosend it alot on the dyno
it sqeeks alot when just driving and letting go of the gas
http://youtube.com/watch?v=S1f5LUd1MWc
less surge tho
dont really hear BOV at all
it surges for a sec and stops
and this is how it stands
"type s bov style with the less stiff of the two springs in it"
i tryed it with the stiff spring only
same sweeks
but i dont hear surge or bov at all!WTF
arg
i was told that the TYPES sounds like surge?
might just have to let it surge/not sweek on the dyno or something so it holds boost
im stumped
less surge tho
same sweeks
arg
im stumped
i had that same problem before with the real type S. ended up being my vacuum lines sum how got cloged. where did u t ur bov to?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b18BoostedDC2 »</TD></TR><TR><TD CLASS="quote">i had that same problem before with the real type S. ended up being my vacuum lines sum how got cloged. where did u t ur bov to?</TD></TR></TABLE>
vaccum manifold
ill pull it with car running and see if its clogd
vaccum manifold
thats compressor surge. I had my real greddy bov hooked up and i thought it sounded a little funny. It didnt sound like any other BOV i ever heard before. Turns out it wasnt the BOV it was compressor surge (same thing you have)
I dont know how you have yours hooked up but the little nipple at a angle should vo back into a pre-throttle body charge pipe, and the bigger nipple to a vacuum source. I had mine going to my GE vacuum manifold, but tapped my manifold after the check valve. That caused imporper vacuum and my BOV would not work. I moved it to the FPR vacuum source and it works beautiful.
