Need help with my Greddy Boost controller!!!
Old Sep 5, 2006 | 11:30 PM
Uniquerootz's Avatar
Default Need help with my Greddy Boost controller!!!
Wassup everyone, well ive been working on my coupe for about a month already. Did a Dohc Zc swap for it and going turbo. I have everything setup up right, but this is where my problem comes, I bought a Greddy profec B Spec 2 boost controller of some guy and he gave me everything but the manual. I had someone help me install it but we are not sure if it came out right. the car is sitting on jackstands at the moment, so we have been reving in neutral and the gauge wont pass the number zero. It only jumps to zero and thats it. well i ws wondering if i would need to have the car actually rolling and in gear in order for it to boost the pounds we are trying to have it throw or if we might have connected some of the hoses wrong. This is my first turbo project so im not very well on the 411.Im not sure if you guys understand what im trying to explain but if u have an idea, i would surely appreciate it. Thanx alot!!!
Old Sep 6, 2006 | 03:21 AM
boostedcivicsir's Avatar
Mr. Badwrench
Default Re: Need help with my Greddy Boost controller!!! (Uniquerootz)
unless you are on the rev limmiter, and even then you will only build a few lbs of boost. the engine needs to be under a load to make boost.
my car at 8200 on the 2 step limmiter makes 7-8 psi.
Old Sep 6, 2006 | 04:07 AM
EddieCRX's Avatar
Default Re: Need help with my Greddy Boost controller!!! (boostedcivicsir)
I found this on the Greedy site some weeks ago
Scroll down to your product and open the link, it's a full install and flow chart, also helps you set the thing up.
If you don't know how to set one of these up it's a real ****, kpa to psi, % gain start boost bla bla bla, I worked it out in the end.
Try this
http://www.greddy.com/tech/
Old Sep 6, 2006 | 11:25 AM
Default Re: Need help with my Greddy Boost controller!!! (EddieCRX)
Thankz alot!!! ill check out and see what i might be doing wrong!!
1baddturbosi
Feb 21, 2007 07:41 AM
Pikachu
Oct 20, 2006 09:18 PM
brixity
Aug 27, 2004 07:44 PM
TURBO B
Jun 5, 2003 07:09 PM
uneekcrx
May 22, 2002 04:33 AM
