ehaust leak
Old Sep 6, 2006 | 09:14 PM
rdssk8rcs1's Avatar
Default ehaust leak
could a exhaust leak before my wideband sensor and my stock o2 sensor cause the car to run lean even if the car is tuned with handata?
Old Sep 7, 2006 | 08:01 AM
adseguy's Avatar
Default Re: ehaust leak (rdssk8rcs1)
an exhaust leak will report leaner conditions then are actually happening. If you use the stock o2 sensor with closed loop enabled then you will run richer then you need to.
Old Sep 7, 2006 | 07:44 PM
rdssk8rcs1's Avatar
Default Re: ehaust leak (adseguy)
hmmm well im running leaner than normal almost all the time, my hondalogger is telling me that the 02 sensors are changing the are fuel ratio by about -5% what could cause this change then?
hondaman1212
Aug 2, 2008 06:33 PM
SiR HatchAlot
Apr 11, 2005 06:59 PM
TheHatchHog
Oct 12, 2004 07:18 AM
EK45VTi
Jul 31, 2003 12:47 PM
samagon
Feb 25, 2002 01:49 PM
