Intercooler efficiency question...
Old Sep 2, 2006 | 03:43 AM
kf6ytc's Avatar
Default Intercooler efficiency question...
Hey guys....
I purchased a FMIC from SSAC on ebay, i've been running it on my car for about a year and i've had no issues.
I've started taking my car a little more serious and i've upgraded turbo's, etc so now i'm begining to question the quality/efficiency of the SSAC peice.
What do you guys think? Junk? good?
Old Sep 2, 2006 | 12:21 PM
kf6ytc's Avatar
Default Re: Intercooler efficiency question... (kf6ytc)
anyone?
Old Sep 2, 2006 | 12:27 PM
dpetro1's Avatar
whats the specs? core size? inlet and outlet size? core size will be the key factor but it seems like people have good results with the ebay intercoolers.
Old Sep 2, 2006 | 12:44 PM
BB6-213's Avatar
is that one for an evo?
Old Sep 2, 2006 | 12:56 PM
kf6ytc's Avatar
Default Re: (BB6-213)
Yeah, it's for my evo.
specs:
Length 32"
Height 12.5"
Thickness 3.5"
Inlet 2.5"
Outlet 2.5"
Compress Air Flow Rate <600Cubic Feet/Min, Rated to ~500 Max HP
Working Pressure: 35~40PSI
Pressure Drop 2~5psi@35psi; 0.2~0.5psi@15psi
Hot Air Temperature 32°F~302°F (0°C~150°C)
Material 100% Aluminum
Design Bar and Plate
Construction Machine Cut and Stamped, Hand Welded
Finish Polished
Net Weight 18 lbs
Old Sep 2, 2006 | 01:31 PM
dpetro1's Avatar
Default Re: (kf6ytc)
yeah it looked pretty good sized. i dont see why it wouldnt work. what are your HP goals?
Old Sep 2, 2006 | 02:58 PM
kf6ytc's Avatar
Default Re: (dpetro1)
My goal is only about 450awhp ... I've heard some rumors that the core is from a radiator or something to that effect, so im just concerned that it's not as efficient as it could be, i'd hate to pay for dyno time and tuning only to find out that another brand of intercooler could have made me 50+ more hp....
TJ
Old Sep 2, 2006 | 03:53 PM
dpetro1's Avatar
that fmic has a pretty big core size. its comparable to the biggest pwr and full-race cores that support 600whp. dunno if it gonna be as effecient but since you already own it you might as well use it until it becomes a problem. keep an eye on the IATs and if they are getting too high then maybe you can upgrade, but until then i'd go for it.
Old Sep 2, 2006 | 05:51 PM
EJ1 wilcox's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kf6ytc &raquo;</TD></TR><TR><TD CLASS="quote">... I've heard some rumors that the core is from a radiator or something to that effect,</TD></TR></TABLE>
I don't think I've ever seen a bar and plate radiator before. But, an intercooler basically is a radiator. It's just a heat exchanger, which is what a radiator is, except it has air running through it instead of coolant.
I would say, as long as it's not leaking, and your IATs are in check, then let her rock
No need to go spending your hard earned $$ on a new intercooler if you don't need one.
Purple-skunk
Mid-Atlantic (Sales)
Mar 7, 2014 07:36 AM
jdmstyler
Jul 25, 2007 12:26 AM
chicken head
Jul 26, 2006 04:51 AM
s-tech
Jul 1, 2005 06:03 PM
DC2 to AP2
Dec 17, 2004 09:50 AM
