Full-Race cam gears...
Old Sep 2, 2006 | 03:32 PM
nebulight's Avatar
Default Full-Race cam gears...
Well, I picked up a set of full-race cam gears from honda-tech. Well, I checked with the instructions on full-race's site, and it said that I should only use the cam gear attaching bolts and washers that were included. Full-Race Cam Gear Instructions But I bought them used, so I only got the cam gears:
Will I be okay if I reuse my stock ones?
Modified by nebulight at 8:43 PM 9/2/2006
Old Sep 2, 2006 | 03:41 PM
NJIN BUILDR's Avatar
Default Re: Full-Race cam gears... (nebulight)
The instructions are pretty specific about using their bolts and washers.If you bought them new shouldn't they have come with all the hardware?I would just get the right parts on Tuesday.
Old Sep 2, 2006 | 04:42 PM
nebulight's Avatar
Default Re: Full-Race cam gears... (NJIN BUILDR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NJIN BUILDR &raquo;</TD></TR><TR><TD CLASS="quote">The instructions are pretty specific about using their bolts and washers.If you bought them new shouldn't they have come with all the hardware?I would just get the right parts on Tuesday.</TD></TR></TABLE>
Yea, I think they might be a different length, I was just curious to see if anyone did them with the stock bolts and it was fine. Because honestly I don't see why you should have to change them unless they are thicker where the bolt goes threw the cam gear....
komat's Avatar
they are meaning the 6 hex bolts that holds the cam gears togather. not the 14mm bolt that tighten down to the camshaft
Old Sep 2, 2006 | 04:44 PM
nebulight's Avatar
Default Re: Full-Race cam gears... (komat)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by komat &raquo;</TD></TR><TR><TD CLASS="quote">they are meaning the 6 hex bolts that holds the cam gears togather. not the 14mm bolt that tighten down to the camshaft</TD></TR></TABLE>
No it has two torque specs listed under instructions one for the adjustment bolts and one of the cam gear attaching bolts.
Old Sep 2, 2006 | 05:24 PM
Soccerking3000's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nebulight &raquo;</TD></TR><TR><TD CLASS="quote">No it has two torque specs listed under instructions one for the adjustment bolts and one of the cam gear attaching bolts.</TD></TR></TABLE>
doesnt mean its supposed to come with the gear attachment bolts
Old Sep 2, 2006 | 05:31 PM
nebulight's Avatar
Default Re: Full-Race cam gears... (Soccerking3000)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Soccerking3000 &raquo;</TD></TR><TR><TD CLASS="quote">
doesnt mean its supposed to come with the gear attachment bolts</TD></TR></TABLE>
if you click the link, it says:
Cam gear attaching bolt: Please refer to your Honda Factory Service Manual for the correct procedure.
Only use the bolts and wasters provided. They should be tightened to 40~42lbft.
http://www.full-race.com/artic...l.pdf
I think I'm just going to wait for Full-Race to e-mail me back.
Old Sep 2, 2006 | 08:30 PM
Full-Race Javier's Avatar
whoops...that's a typo. should read use the OEM hardware (bolts & washers) to fasten the gears to the cams.
updated instructions :D
Old Sep 3, 2006 | 05:16 AM
nebulight's Avatar
Default Re: Full-Race cam gears... (Full-Race Javier)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Full-Race Javier &raquo;</TD></TR><TR><TD CLASS="quote">whoops...that's a typo. should read use the OEM hardware (bolts & washers) to fasten the gears to the cams.
updated instructions :D</TD></TR></TABLE>
Thanks Javier!
Old Sep 3, 2006 | 06:37 AM
nerdhotrod's Avatar
So this is where you lurk now...
Let me know when you want to come up and play with these things.
Old Sep 3, 2006 | 08:07 AM
master honda tech's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NJIN BUILDR &raquo;</TD></TR><TR><TD CLASS="quote">The instructions are pretty specific about using their bolts and washers.If you bought them new shouldn't they have come with all the hardware?</TD></TR></TABLE>
I agree.
Halo
Oct 21, 2016 07:29 PM
The Si
Feb 22, 2007 10:36 PM
robcrx
Apr 9, 2006 07:35 PM
b00sted4dr
Oct 19, 2004 08:31 PM
HYREV2NR
Jun 18, 2003 07:25 AM
