Boost Gauge Reading
Old Sep 7, 2006 | 12:06 PM
nicktagz's Avatar
Default Boost Gauge Reading
I had a question about the boost gauge I know it will read about -20 or -30 without the turbo installed on the car yet but when the turbo is put on will the readings be the same or will the gauge read 0 while its idoling?
Old Sep 7, 2006 | 12:07 PM
Kelly.'s Avatar
I've quit using this account
it will still read the same vacuum once the turbo is put on.
Old Sep 7, 2006 | 12:09 PM
nicktagz's Avatar
Default Re: (Kelly.)
would you happen to know if about how to install the missing link for the map sensor cause i put it on and my car was idoling like ****.
Old Sep 7, 2006 | 12:25 PM
Kelly.'s Avatar
i have never went the missing link route, but i thought you just add it in between the map sensor and the IM
do a search,
i found this when i searched
Your search for missing link returned 227 results.
search missing link, archived and search the FI forum
good luck
Old Sep 7, 2006 | 12:51 PM
JoePSI's Avatar
the missing link goes under your stock map sensor. correct.
Old Sep 9, 2006 | 07:28 PM
nicktagz's Avatar
Default Re: (JoePSI)
yea but whats the purpose of the hole in the side of the missing link? Cause when I hooked the missing link up to my map sensor my car was link struggling and idoling like ****.
Old Sep 9, 2006 | 07:59 PM
SovXietday's Avatar
Default Re: (nicktagz)
You run a vacuum source to it.
Get rid of the missing link ****, and run crome or uber.
Old Sep 9, 2006 | 08:38 PM
siblues's Avatar
Default Re: (SovXietday)
The missing link should come with these little filters that look like a cigarette filter and one of those goes in the hole.My car did the same when i didnt put it in so i just taped the hole closed until they sent me a new one.Just tape the hole closed and see if that fixes the idling issue?
Old Sep 10, 2006 | 09:05 AM
nicktagz's Avatar
Default Re: (siblues)
no i tried that it didn't work
Old Sep 10, 2006 | 11:38 AM
JoePSI's Avatar
ROFL, that hole should be open. the filter sits in there. All a missing link does is hide boost from the ECU(by hiding it from the map sensor). A missing link is not going to fix an idling issue. If you are running more than 10psi get a 2.5/3bar map sensor and get your car tuned. dont mess around with Missing links and FMU's. Get a basemap get to a tuner and get your car done right. Trust me im rebuilding because of that crap.
chrisfromsrq
Sep 26, 2009 12:20 AM
D16-t_coupe
Dec 2, 2007 04:19 PM
nicktagz
Sep 8, 2006 11:01 AM
l2yanE
Oct 2, 2005 10:15 AM
94greddycivic
Jun 29, 2004 10:51 AM
