Lookin to get 350hp out of a b18c1. What setup should i go with?
HELP! Lookin to get 350hp out of a b18c1. What setup should i go with?
hey i have a built gsr motor and im shooting for 350 street horsepower. heres my set up. i just recently wrecked my car and the whole front end was gone. including my turbo/manifold/intercooler . so im lookin for a new setup. do you guys think topmount is an overkill for 350hp? and i was thinkin gt30r turbo.
1997 GSR B18C VTEC eastco machining
>>>>>Fully built head from Port Flow Design
>>>>>RC throttle body
>>>>>ARP head studs
>>>>>Skunk2 cam gears
>>>>>Type-R pulley kit
>>>>>AEM fuel rail/regulator
>>>>>JE pistons 9:5.1
>>>>>Crower Piston Rods
>>>>>Tial wastegate
>>>>>msd digital-7 plus ignition control PN 7520
>>>>>Apexi exhaust
>>>>>custom 3" straight piping
>>>>>JG edelbrock intake manifold
>>>>>RC throttle body
>>>>>ARP head studs
>>>>>Skunk2 cam gears
>>>>>Type-R pulley kit
>>>>>JE pistons 9:5.1
>>>>>Crower Piston Rods
>>>>>Tial wastegate
>>>>>Apexi exhaust
If you only want 350, a stock GSR with a good (Full-Race) turbo kit would've done that for you. Why stop at 350 with that much money into the motor?
Re: (BLKTeg94)
well this was also going to be my daily driver so i built it to be reliable and make good power with the peace of mind of it not going to blow
Re: (BLKTeg94)
For street i thought topmount was overkill.... sure it did great on the track boostin large but for street it only makes power on high rpm.... a lot of lag. i suggest ramhorn. but for only 350, a blox turbo manifold will do jus fine
Re: (Five Liter EATER)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Five Liter EATER »</TD></TR><TR><TD CLASS="quote">For street i thought topmount was overkill.... sure it did great on the track boostin large but for street it only makes power on high rpm.... a lot of lag. i suggest ramhorn. but for only 350, a blox turbo manifold will do jus fine
</TD></TR></TABLE>i dont know what kind of topmount you were using but my fr topmount wasnt laggy at all with my old gt4067s setup...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by illestaznpimp »</TD></TR><TR><TD CLASS="quote">well this was also going to be my daily driver so i built it to be reliable and make good power with the peace of mind of it not going to blow</TD></TR></TABLE>a gt30r will have no problem making 350whp on a built motor and imho a topmount will work fine,but is not necessary if your budget does not allow it...350whp on a built motor is fairly easy to achieve
Re: (reactiondc2)
If you are looking for low horsepower and a reliable setup, dont waste your money on a top mount manifold. instead spent the money to build the engine. ITs also your daily driver so will want to keep A/c. I would probably go with an a/c compatible ramhorn or a manifold like SP's Quick4AC.
Re: (reactiondc2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by reactiondc2 »</TD></TR><TR><TD CLASS="quote">i dont know what kind of topmount you were using but my fr topmount wasnt laggy at all with my old gt4067s setup...
a gt30r will have no problem making 350whp on a built motor and imho a topmount will work fine,but is not necessary if your budget does not allow it...350whp on a built motor is fairly easy to achieve </TD></TR></TABLE>
yeah i wanted to go gt30r/top mount and run low boost, maybe 9-11 psi's and try to achieve 350hp and have the option to crank up the hp later on if i do decide to go all out and i wont have to change the whole setup, i would have to just turn up the boost
Re: (blackeg)
Deciding to 'turn up the boost later' is always a dumb thing to say IMHO. If you have someone tune it, you go big or go home. If the motor can support 500whp, you have the faintest desire for it in the future, AND you decide to get a turbo to support it... tune it at that number, then just run it low boost 95% of the time.
With that setup w/ac, you'd be maxing a 50 trim t3/t04 at that power level (base budget level), but for $$ a gt30r would give you a bit more room to breathe. Just don't go too big - people such as above that say a gt40 isn't laggy at all aren't talking about 5th gear cruising on the expressway. If you can't build much boost at highway speeds in 5th, then its not what I'd consider a fun daily driver. Thats more of a weekend strip car you drive during the week...
Re: (HiProfile)
[QUOTE=HiProfile]Deciding to 'turn up the boost later' is always a dumb thing to say IMHO. If you have someone tune it, you go big or go home. If the motor can support 500whp, you have the faintest desire for it in the future, AND you decide to get a turbo to support it... tune it at that number, then just run it low boost 95% of the time.
yeah i agree with you. tuning isnt cheap and i DO have a avc-r boost controller with the boost by gear setting but i was wondering is it safe to tune it at 500hp then turn the boost down all the way 95 percent of the time until i decided to go race? wont it still shoot buttloads of fuel? cause im pretty sure the avc-r just opens the wastegate sooner right? if theres another way or if anyone has done this let me know how they did it and how it turned out for them.
Re: (illestaznpimp)
one of the main reasons is that my i still have stock sleeves. i heard gsr sleeves are good up to like 450hp, correct me if im wrong.
Re: (illestaznpimp)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by illestaznpimp »</TD></TR><TR><TD CLASS="quote">[QUOTE=HiProfile]Deciding to 'turn up the boost later' is always a dumb thing to say IMHO. If you have someone tune it, you go big or go home. If the motor can support 500whp, you have the faintest desire for it in the future, AND you decide to get a turbo to support it... tune it at that number, then just run it low boost 95% of the time.
one of the main reasons is that my i still have stock sleeves. i heard gsr sleeves are good up to like 450hp, correct me if im wrong.</TD></TR></TABLE>the sleeves are only as good as your tuner...contact ht member leed(somewhat of a local,great pricing),he tuned my old stock sleeve setup(10.0:1 compression) on 24lbs(sc61) and it never had a problem at all
Re: HELP! Lookin to get 350hp out of a b18c1. What setup should i go with? (illestaznpimp)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by reactiondc2 »</TD></TR><TR><TD CLASS="quote">the sleeves are only as good as your tuner...contact ht member leed(somewhat of a local,great pricing),he tuned my old stock sleeve setup(10.0:1 compression) on 24lbs(sc61) and it never had a problem at all</TD></TR></TABLE>
do you have his number and what are his prices? i dont know how to work the search to contact him. i see that ur from washington. whats semi-local? oregon?
Re: HELP! Lookin to get 350hp out of a b18c1. What setup should i go with? (reactiondc2)
Peakboost kit all the way. I love mine, makes over 400hp at 14 psi using a t3/t04e 60 trim. Its simple and efficient
alperx
06-25-2012 11:11 PM
