Anyone heard of this? DTAFast Engine management
I was recommended this by my tuner http://www.dtafast.co.uk/S_60_PRO.htm for my H22 CRX turbo project. Just thought I'd share it with you as its kinda different. Its a UK designed Engine management unit for high revving 4 cylinder engines. My tuner has had a crank trigger wheel bolted on the crank pulley witha micrometer and a ford crank sensor is going to be used also somewhere along the line. Let me know what you think...
ECU Functions
Engine Configuration
20,000 rpm capability
Flexible and easily adapted to different OEM, crank, cam sensor arrangements.
Genuine four and two stroke support.
Twin spark engines.
Twin injector engines.
Sequential or grouped injection.
Individual coils, wasted spark or distributor.
Unequal coil firing capability.
Unequal injection angle capability.
Delayed sequential injection.
User controlled fan activation.
Sensors can be calibrated individually with a lot of preset options supplied.
Flexible Tacho Output
soft and hard rev limits
Main Fuel and Ignition Functions
Two main fuel, spark and turbo maps selected by a dashboard switch.
Comprehensive start up fuelling options both time and temperature dependant.
Air, coolant and manifold pressure compensation maps.
Throttle transient increase compensation.
Throttle transient reduction compensation.
RPM and load breakpoints can be calibrated by the user.
Throttle or MAP as load.
All maps with one or two dimensional with interpolation as required.
Lambda control functions
Extensive lambda parameters table to ensure stable closed loop operation and emissions requirements can be met where needed.
Full three dimensional lambda target map.
Auto-tuning function.
Turbo Control Functions
Open or closed loop turbo pressure control via PWM valve.
Modify target turbo pressure by gear selected.
Modify target turbo pressure by vehicle speed.
Two control maps selected by switch on dashboard.
Active base PWM map for easy calibration.
Idle Control Functions
Open or closed loop idle speed control via PWM valve.
Closed loop idle target speed temperature dependant.
Fuel enrichment table calibrated versus PWM percentage.
ALS Control Functions
Full ALS ignition and fuel maps.
ALS valve control together with map switching controlled
by dash board switch.
Cam Control Functions
Open or closed loop cam advance control via PWM valve.
Static offset table to zero out electrical movement effects.
Active Cam Target Advance map, load and speed dependant.
Water Injection
When not being used to control the camshaft, cam base PWM map can be used instead for water injection, giving complete load and speed dependence.
Flexible Input/Output
Three uncommitted input tables which use 0 5 volt inputs or any input the S60 knows already, linked to fuel and advance modifiers and a PWM output.
Launch Control
Fully flexible first gear launch capability.
Extensively tunable to individual vehicles.
Full Throttle Gear Shift Cut
Shift cut capability with 1ms resolution, variable for each gear with
full switch de-bounce capability.
Voltage Compensation Tables
User configurable voltage compensation tables for injector dead time
and coil on time (dwell time).
Firmware
The ECU firmware is flash upgradeable via the serial port with a special cable and software. Current firmware and software published on http://www.dtafast.co.uk.
CAN PC Communications.
The ECU can communicate with the PC via our
USB -> CAN converter. This solves the problem
of unreliable USB -> RS232 converters.
Data Logging
Up to thirty six separate items can be logged.
Three user selectable logging frequencies.
Up to nine hours logging capability.
Graphing can be done on-line to the ECU.
Diagnostics and Test Features.
Full sensor diagnostics and fault recording.
Extensive engine run time recording at different load and speed conditions.
Ability to exercise injectors and coils without engine running for fault finding.
ECU Functions
Twin spark engines.
Water Injection
Launch Control
Firmware
Data Logging
I know of 3 cars with DTA, two are 240's with RB motors, one makes 1000rwhp the other makes 800rwhp and the 3rd car is a mazda protege, but it only makes 300hp. it looks alot like aem software wise.
Re: (blackeg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blackeg »</TD></TR><TR><TD CLASS="quote">from what ive heard, it can be more complex to tune, but yeild awesome driveability. i think one of my friends is running it on his car</TD></TR></TABLE>
My tuner seems to think it shall be less setup time than the Hondata S300 I had and coupled with my wideband LM-1 should auto tune while I drive.
Its also got a built in boost control
I'd be interested to hear of any turbo hondas running this?
Re: (djnikko)
Talk with Don Flores. DonF is his username. I've dyno'd n/a road racing B18C originally done by him using DTA. He has his own DTA system which he uses w/ his engine dyno and is thoroughly experienced w/ it on Honda's.
Jim
Jim
Re: (iBrandon)
seen it used on a turbo gsr back in the day and also a turbo bmw. both made good numbers and ran for years. i guess as with any system... it's only as good as the tuner.
Re: (M.A.R.C.)
dta works good, but finding people familiar with it is hard. I have a customer with dtafast on an fd3s rx7 thats kinda stuck. The software is kinda clunky and it uses a weird *** cable to connect it to the laptop which i cant find, so i cant really do anything for him. Hopefully he'll find the proper cable from the guy he bought the car from. its very simple though, i think the one in the fd has like 15-20 wires going to it.
Re: (djnikko)
Assuming you have an obd1 Honda, there is no way in hell that it could be less setup time than the S300. Plug it in, upload the basemap, and drive. No wiring needed for the S300. Yes, it will do boost control with an external solenoid.
Re: Anyone heard of this? DTAFast Engine management (djnikko)
I have the DTA p8pro in my civic -88 hb with a gt35r b16 and made 587hp in an engine dyno @ 2bar. I have not yet run the car with this engine but it runs extreamly smoth in the enginedyno anyway.
I like that you can hook up an ignition coil/cylinder directly to the ecu and you don´t need any cdi boxes or other stuff. It don´t have alot of analog inputs ether for datalogging. But over all I like it accept for all the PID regulator stuff.. It is realy hard to figure it out how to make it regulate the lambda controll and boost controll and all the fetures that needs to have correct PID values figured out. I know of several setups that ended up using external boostcontrollers and ditched the lambda controll features.
I will deal with it some more when i get the engine running in the car. I will probebly foul around with restrictions for the boost hose to the boost solenoid/WG to see if I can get a stable boost.. the problem is that the boost contoll is not stable.. It fluctates very heavely.. same thing withe the lambda controll..
If I cant´t make these fetures work I will recomend Autronic or aem instead.
Re: (locash)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by locash »</TD></TR><TR><TD CLASS="quote">Assuming you have an obd1 Honda, there is no way in hell that it could be less setup time than the S300. Plug it in, upload the basemap, and drive. No wiring needed for the S300. Yes, it will do boost control with an external solenoid.</TD></TR></TABLE>
And if your tuner sells you a box on it's ability to autotune while you drive, i'd find another tuner....
Re: (tony1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tony1 »</TD></TR><TR><TD CLASS="quote">
And if your tuner sells you a box on it's ability to autotune while you drive, i'd find another tuner....</TD></TR></TABLE>
that too
that too
Our local tuner uses it well. Made 600whp on his civic probably 7 years ago now. COP setup, pretty cool for back in the day. I think the shop VW rabbit uses it too, makes 500+ too.
Re: (tony1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tony1 »</TD></TR><TR><TD CLASS="quote">And if your tuner sells you a box on it's ability to autotune while you drive, i'd find another tuner....</TD></TR></TABLE>
i think he just was pointing out the "plug n play" capability by retaining the stock ecu.
Re: (M.A.R.C.)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by djnikko »</TD></TR><TR><TD CLASS="quote">
I'd be interested to hear of any turbo hondas running this?</TD></TR></TABLE>
I agree with Joe, my comment was about this /\
Re: (hybrdthry911)
The problem comes with being in the UK not many people are familiar with hondata (there are a few tucked away on forums but noone who specializes). I think he meant the auto tune feature is handy for if I decide to up the boost or add any cooling upgrades etc etc. The DTAFast unit is a standalone ECU, I shall not need my honda ecu to run this like I would with the hondata
It seems alot of people are making good power with this unit so i'll see how to goes from here, once its up and running who knows maybe i'll be doing the tuning .......tick tick boom
Thanks for the feedback guys
Re: (tony1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tony1 »</TD></TR><TR><TD CLASS="quote">I agree with Joe, my comment was about this /\</TD></TR></TABLE>
whoops... missed that part
yeah... i think he needs to rethink who he's letting tune his car then.
Re: (M.A.R.C.)
I have no other options here in the UK. Unless someone wants to fly out to me
Ive just finished day 1 of the efi101 beginners course and this has kind of inspired me to have a go myself but I shall avoid the temptation and learn once its been setup if I feel confident.
Re: (djnikko)
Guy @CPL is a UK agent for Hondata and runs a few quick cars as a result.
DTA is ok I used to run it on my old T16 Rover (400 UK BHP) a few years ago, most UK tuners will use DTA because that's all they know.
Have a word with Dave Walker, he tunes Honda's on his own managment system and if you've been around you'll know about Dave.
Motec seem to be into Honda's as well, loads of tuners play with that kit.
Abbey Motorsport may be able to help you, I know Norris done a couple of Honda's last year.
You need to research a little more, don't get me wrong DTA is good but Hondata is going to be the way forward.
Eddie
Eddie
Hi,
I'm currently installing DTA p8pro on my B16A as well. but i just couldn't get to engine to run. Can you please share with me your base map?
thanks,
JoE
thanks,
JoE
