Change Cams
Old Sep 6, 2006 | 02:49 PM
First Swap's Avatar
Default Change Cams
I will be running a JDM B16 (EG hatch) with:
Gt28rs T3 (set at 10psi)
Neukin Ramhorn Mani
Neukin 3" Downpipe
Hondata (Tuned by a local shop)
There doesn't appear to be much in terms of archived info for b16/disco potato combos. The question is I am going to be ripping the head apart to put in some ARP head studs, while I have everything apart should I also switch from the stock B16 cams to GSR or TR.
Before I start getting slammed with the "goals" posts, here is what I had in mind. 98% street use, some occasional road racing and maybe a trip or two to the strip.
Thanks for any worth while info/dyno charts, etc.
Modified by First Swap at 4:07 PM 9/6/2006
Old Sep 6, 2006 | 03:09 PM
boostedcivicsir's Avatar
Mr. Badwrench
Default Re: Change Cams (First Swap)
well anything is better than the b16 cams. i made 540 on a conservative tune with my gsr's. swapped them out for the mazworx cams and have mine for sale with tru time adj gears. pm me if interested. and oh yeah, i am an 84mm stock crank'd b16.
LSTEG98
Dec 28, 2007 06:36 PM
LSEGHATCH
May 17, 2006 09:56 PM
SOHCZCHatch
Nov 10, 2004 05:45 PM
SuperCivic
19
Jun 28, 2002 07:09 PM
