resistor ?
Old Sep 7, 2006 | 05:55 PM
wrinkles's Avatar
Default resistor ?
14b with a -3an line from the stealmodeperformance kit. do i need a restrictor on this setup or no? i already searched and am getting mixed results...
Old Sep 7, 2006 | 06:17 PM
boostedcivicsir's Avatar
Mr. Badwrench
Default Re: resistor ? (K Stef)
i had -3 on my drag kit forever with no restrictor. no issues.
talked to f-r geoff and he assured me that -3 w/o a restrictor is fine for the t3t67ho i am running now.
Old Sep 7, 2006 | 06:19 PM
siblues's Avatar
Most people on here are going to tell you you dont need a restrictor with a -3an line.It all depends on what psi you are putting out at full throttle.
Old Sep 7, 2006 | 07:41 PM
wrinkles's Avatar
Default Re: resistor ? (siblues)
psi of boost or oil to the turbo?
if your talkin boost its a stock 14b so it wont go much higher than 10psi
and kinda off topic but did any of you use teflon tape on the threads or is that not necessary?
Old Sep 7, 2006 | 08:37 PM
wrinkles's Avatar
found the answer to the teflon question, but the other im still wondering about
Old Sep 7, 2006 | 09:07 PM
IIISport.com's Avatar
They are talking about the oil pressure.
The restrictor is really a thing that you asses after running the turbo. If you have oil leakage, and think it is from high pressure, then you get it. Otherwise many people run fine without them.
Old Sep 7, 2006 | 09:17 PM
wrinkles's Avatar
Default Re: resistor ? (IIISport.com)
cool thanks, ill try without it at first
CTR_B
Jun 5, 2008 03:28 PM
Dominick331
Apr 5, 2006 02:13 PM
willyboyK20
Jan 8, 2006 05:58 PM
SpoolnByYou
Dec 11, 2005 02:40 PM
Turboredteg
Feb 7, 2005 06:38 PM
