Mounting intercooler, how have u done it??
Old Sep 5, 2006 | 03:29 AM
JordanCivic's Avatar
Default Mounting intercooler, how have u done it??
Hi guys, just recieved my new precision intercooler, it has two tabs on the end cans, just wondering how u guys have used these to mount to the body?? pics would help if poss.
EK 99
many thanks
Old Oct 3, 2006 | 03:27 PM
bmw626's Avatar
Default Re: Mounting intercooler, how have u done it?? (JordanCivic)
bump i need ideas for mounting mine too
Old Oct 3, 2006 | 03:53 PM
1baddcivicsi's Avatar
Default Re: Mounting intercooler, how have u done it?? (bmw626)
L-brackets and self tap screws are the best way to go
Old Oct 3, 2006 | 04:37 PM
sc4dr's Avatar
Default Re: Mounting intercooler, how have u done it?? (1baddcivicsi)
I would use nuts and bolts instead of self tappers.
Old Oct 3, 2006 | 05:30 PM
bmw626's Avatar
Default Re: Mounting intercooler, how have u done it?? (sc4dr)
how do you know exactly howto center it? doesn't it have to be perfectly measured so that the intake side and exhaust side pipes all match up evenly?
Old Oct 3, 2006 | 06:18 PM
Schister66's Avatar
Man U FTW
i drilled holes in the bumper support and put a bolt and washer through the mounting bracket on the top of the IC
Old Oct 3, 2006 | 06:25 PM
vg7z's Avatar
I just put a dozen zipties on em. Im dead serious too.
Old Oct 3, 2006 | 06:36 PM
slodc2's Avatar
Default Re: (vg7z)
i drilled holes thru the tabs and twist tied them around the bumper beam also
Old Oct 4, 2006 | 08:33 PM
bmw626's Avatar
Default Re: (slodc2)
pics? just for the hell of it
Old Oct 4, 2006 | 08:55 PM
JDMRice's Avatar
Default Re: (bmw626)
here u go hope it helps, Do it right the first time around, Zip ties may work, but wont last to long.
Used a jack to move it into place
bent a piece of steel drilled it and bolted it to the rebar+ IC
Used to sell tapping screws on the bottom.
Old Oct 4, 2006 | 09:02 PM
TDautowerkes's Avatar
i welded 2 tabs on the bottom and bolted it to the lower rad support then welded 1 and bolted it to the pice in the cenbter of the rad support where the horn is....
Old Oct 4, 2006 | 09:04 PM
redboost10's Avatar
Default Re: (JDMRice)
i tack welded two tabs with a pre-drilled hole on the bumper support. 1st center the intercooler under the bumper support then mark the two ends of the intercooler, then make some brackets out of some tagboard then out of steel, drill out where the tapped holes are on the ic and there you have. ill take some pics this weekend
Old Oct 4, 2006 | 09:33 PM
adictionbass's Avatar
Default Re: (redboost10)
heres what i did
Old Oct 4, 2006 | 10:46 PM
Schister66's Avatar
Man U FTW
pics of mine....idk if this helps or not, but here goes
pjr710
May 9, 2008 04:18 PM
TunerShark
Feb 25, 2007 09:07 AM
redboost10
Aug 2, 2006 08:50 AM
pissedoffsol
Aug 13, 2003 02:58 PM
turbospool
Mar 10, 2003 01:35 PM
