flex pipe with no flex?
Old Sep 7, 2006 | 10:10 AM
champLSinteg's Avatar
Default flex pipe with no flex?
I just a 6in with 4in flex pipe that I ordered. The dang thing has no give that I can tell. The inside of it is ribbed (accordion-like) steel. Is it supposed to be like this? if it is then how does it work or how well does it work? I am thinking of sending it back because I was told it shouldn't be ribbed like that on the inside and it should "flex". What do you guys think?
Old Sep 7, 2006 | 10:14 AM
david@didrace.com's Avatar
Default Re: flex pipe with no flex? (champLSinteg)
A short one isn't going to flex that much. And you have the better type for the inside, you don't want it to be braided stainless on the inside.
Old Sep 7, 2006 | 11:14 AM
Default Re: flex pipe with no flex? (backpurge)
Do you think I should have gone with a longer one?
Old Sep 7, 2006 | 11:45 AM
turbotime's Avatar
my flex from atpturbo.com is flex inside and out, its a 3" diameter 6" long section... "flex bellow" they call it.
Has very little give just holding it in my hand but once it was on the car and the dp was bolted to the exhuast you could see the flexing. its not supposed to be super-loose lol its just to relieve the turbo/manifold of stress fromt he exhaust moving/engine torquing
Old Sep 7, 2006 | 12:07 PM
Default Re: (turbotime)
Is yours stainless braided inside and out then? I can push or bend mine though. With my weight on it I can barely feel it compress but it wont bend.
Old Sep 7, 2006 | 12:35 PM
RCautoworks's Avatar
Your not suppose to be able to flex it bare handed, your engine will do that work for you.
Old Sep 7, 2006 | 12:49 PM
Slammd Sol's Avatar
Default Re: flex pipe with no flex? (90blackcrx)
Exactly, an 8' section of exhaust tubing will do the flexing for you..
unless you're the late andre the giant, no chance of flexing..
Old Sep 7, 2006 | 12:50 PM
Muckman's Avatar
Moderator in Chief
Replace it with a rubber one. It will flex alot.
Old Sep 7, 2006 | 01:20 PM
turbotime's Avatar
Default Re: flex pipe with no flex? (Muckman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Muckman &raquo;</TD></TR><TR><TD CLASS="quote">Replace it with a rubber one. It will flex alot. </TD></TR></TABLE>
lol
Old Sep 7, 2006 | 01:25 PM
Turbo-charged's Avatar
Default Re: flex pipe with no flex? (turbotime)
put good engine mounts in the car and dont worry about it lol
VspecSiR
Jun 25, 2006 03:37 PM
FURACERMAN
Welding / Fabrication
Jan 6, 2006 06:32 PM
Optiks.
Jan 9, 2003 01:24 PM
Etylorcen
Mar 20, 2002 11:20 AM
