Should I use an LSD additive or not?
Old Sep 7, 2006 | 07:15 AM
97turboteg's Avatar
Default Should I use an LSD additive or not?
ok, i think imma go with the honda MTF, now since i just put a type r tranny in my turboed ls. Should I put an additive in or not? I hear some ppl saying to use the GM posi fluid, and how all racers swear by it...
Old Sep 7, 2006 | 07:17 AM
93supercoupe's Avatar
Default Re: Should I use an LSD additive or not? (97turboteg)
I know this isnt related too much but I had a quadracer250 with a slipping clutch, and becuase those clutchs are similar to an LSD I added posi fluid and it stopped slipping for a while.
Old Sep 7, 2006 | 10:30 PM
theinfamouskonrad's Avatar
Default Re: Should I use an LSD additive or not? (93supercoupe)
Nothing is better then genuine honda Mtf... using it in my type r tranny w/ gear speed syncros. Yes Gm syncromesh helps trannies with grinding gears.... but that's the only reason i would use it. If the tranny is screwed to begin with, why not give syncromesh a shot. But if the tranny isn't grinding and shifts fine, definately use Honda fluid
Bigwool
Dec 18, 2004 08:12 AM
tallblondkid
Aug 18, 2004 03:59 PM
JDMCRX
Jun 5, 2004 08:46 PM
under_psi
Jun 24, 2002 09:07 AM
Gump
Feb 28, 2002 04:44 AM
