just finished turbocharging my del sol b16a2 BIG PROBLEMS !!!!!!
hi every one checked the archives didnt get newhere please check this out ....... i havea 93 del sol b16a2 t3 a/r42 comp a/r48 turbine, front mount intercooler, dsm injectors and resistor box, equal length manderel bent manifold, 8psi wastegate, 2.5" downpipe, ...................
Now my prob is basically when i drive the a/f guage is in rich i can only guess 9:1 mixture the smoke out the back is un real thick black smoke when i boost now i know thick black smoke means its well overfuelled but has any one had this ???????? i was thinking to go back to the stock injecktors and see if it would sort itself out ????
Also when i accelerate and the turbo spools up and begins to boost i get horrible missfires which i can only assume is due to tooooo much fuel i replaced my plugs for colder ones (only 1 grade colder ) and closed the gap by 0.1mm what is the ideal plugs ? and ideal gap ? replacing the plugs helped slightly but still very very bad !!!!!
ANY IDEAS WOULD BE SO SO APPRECIATED ;-) THANK YOU
Re: just finished turbocharging my del sol b16a2 BIG PROBLEMS !!!!!! (street sweeper)
try listing the whole engine/turbo kit part by part?Like are you using a fmu and missing link or do you have a ems?The more of a description you give the better everyone can help you
barhonda_delsol
11
04-11-2007 06:10 PM
Chris_V-TEC
12-03-2005 10:32 AM
