Which camber kit
Which camber kit
I have a crx hf Im gonna lower about 2" maybe more but i need a camber kit (i have ground control c-o's & im saving up for shocks)...what do you guys suggest? How much should i put down on a good one? Also (this is way outta left field) i want a tranny with a closer gear ratio....which should i use
Re: Which camber kit (91kriks)
Ingalls makes a good camber kit. Its about $60 bucks per corner. If your using the HF tranny, then go with the Si transmission.
1 Post
I just saw today they have one on JCwhitney.com for around$70ish for the sprint I think it was camber kit to adjust +- 3degrees. That is what you will need with how low you are gonna go.
