car wont start, already tried searching
I tried searching already, my car will not start!!!!! the starter is new, the starter wire is new and the grounds are all connected. The starter doesnt click but i hear fuel going to the injectors.....SOMEONE PLEASE HELP ME!!!! is it the starter relay? and where is it located?
crazy mad murdock
Re: car wont start, already tried searching (verseone)
have you checked all fuses under the hood and the dash, when you turn the car on do you hear the main relay click? (located under the dash against the car).
Try bypassing the starter, by having the car in nuetral, get a peice of wire and connect both connections on the starter to see if it trys to turn over.
Check to make sure all (-) are grounded. Battery, water thermostat, motor, what i mean is sand down the connections incase they have gained rust or some werid poo happened.
Any codes? why did you replace the starter and such? sawp?
Jack Murphy
06-21-2017 06:23 PM
bigboi407
04-09-2016 04:27 PM
cksnah252
12
09-09-2014 07:51 AM
Schultzie
01-23-2013 09:46 PM
