B16a swap question?
B16a swap question?
I might get a b16a Long block from hondamotorsonline.. The engine comes with:Complete motor,intake and exhaust manifold,injectors,fuel rail,throttle body.. Now my question: Can I use my existing Si tranny and driveshaft? I know I have to buy a motor mount for this and a B16a1 ECU right? Also, is hondamotorsonline reliable to order a surplus engine? Your input would be greatly appreciated.. Thanks
[Modified by 4thGSi, 5:13 AM 7/28/2002]
Re: B16a swap question? (big pete)
you cant use your si stuff......use a Bseries tranny and 90-93 integ axles
Re: B16a swap question? (4thGSi)
If you get a B16 you'll need a full swap + a motor mount kit because nothing from your D motor will work. If you get a ZC longblock then you could use your Si tranny, ecu and axles.
Re: B16a swap question? (VTECVillain)
BigDaddyRich
09-08-2002 04:37 AM
