How to put Y* intake manifold on d16a6 motor?
How to put Y8 intake manifold on d16a6 motor?
i cant figure out what parts to use and where to put everything
thanks
Y8 manifold
[Modified by CIV616, 12:36 AM 8/30/2002]
thanks
Y8 manifold
Re: How to put Y8 intake manifold on d16a6 motor? (CIV616)
get a new intake gasket.you need
intake from a y8 ONLY A STANDARD ONE!!!!!!!!!!!!! NOT THE AUTOMATIC!!!!!!!!
throttle body
fuel rail
fuel pressure regulater
use your a6 injectors,theres is no place for the air intake temp sensor.because on 96 and up its on the hose from the air box insted of bolted to the mani itself.you have to extend the map sensor wires a little.the throttle cable will work but you have to mess it to get it to work properly.and you have to cap off one of the vacume hole on the plenum.
if you need any help ask me. OH ITS WORTH IT!!!!!!!!Y8 MANI IS THE ****!!!!
throttle body
fuel rail
Re: How to put Y8 intake manifold on d16a6 motor? (4gvtec)
for a little more flow you could use any b series throttle body. i suggest you bolt it to the manifold and match port it before installing the manifold. y8 will make a big difference.
Re: How to put Y8 intake manifold on d16a6 motor? (2.0CR-XVTEC)
ok so not really and big diff. i have a gsr TB on it already
RSXrunsit
01-19-2004 08:14 PM
