ZC Head Removal
ZC Head Removal
DAMN MAN.... the head bolts are lined up under the cams Is there any way of taking off the ZC head with out removing the cams? I thought about using a swivel, but you just cant get enough torque on that thing to get the head bolts loose.
Anyone have a any good ideas ort tips?
Re: ZC Head Removal (boostinb18)
Ok thanx guys... If i remove the Cams while at TDC I should just be able to reinstall them the same way? nothing in the valve train will pop loose as i pull out the Cams?
