HELP! I failed smog twice...
ok i just tried to pass my 91 si and failed again... the first time in HC i had 177,190 when the max is 130,105, also NO i got 1251,1073 and max is 1088,948 so i did the following
1)changed oil and filter
2)new plugs, wires, dizzy(from HF)
3)new air filter
and i failed again with lower HC 145,138 but higher NO at 1633,1334
please help
3)new air filter
please help
Re: HELP! I failed smog twice... (CR-X)
i was keeping it as hot as i could on the way there i was keeping it above 4k the entire time and left it running while i did the paperwork but when i got to the smog place the freakin hillbillies sit there looking at it for ever just letting it cool down...
Re: HELP! I failed smog twice... (EF_LSVtec)
any recomendations for a cat i guess i want one thats very restrictive to help pass smog... no need for a high flow cuz i wont use it again just once for the smog
Re: HELP! I failed smog twice... (cl4show)
do you have a header,,i bought some cheap header off this guy a while back and when it was time to smog my car,,it didnt pass,,so i took off the header and put the stock exhaust manifold,,passed no problem,,,the mechanic said it was because the header had 2 pipes where the oxygen sensor was and that it was only reading half the exhaust instead of reading the whole exhaust as one,,,i dunno,,thats what he told me
Re: HELP! I failed smog twice... (sitrucjr)
where in socal do you live i know a couple of tricks that can help you and they are completely legal so let me know.
1 Post
Re: HELP! I failed smog twice... (hybridturbo89)
I just went to a local muffler shop and had one installed...make sure its made for your motor. I think mine is made by Catco. I passed with a jdm 4-1 header hidden under a heat shield w/ 1 O2 sensor. (State referree inspection)
well why dont you email me or pm me and i will give you my number and i can take a peek and see what i can do alright??
If you have an FPR, lean it out a little bit, like 4-5 psi. Retard your timing a lot as well. Also spray some carb cleaner into your TB to clean it out.
Re: HELP! I failed smog twice... (sparkz)
adjust your valve lash make sure they are not to tight usually the exhaust valves. did this for a friend and passed the second time, valves where not within specs.
LAO
07-28-2008 07:00 AM
SiRII_Izzy
21
08-24-2004 07:06 PM
